Sneaky Silverado- Cam swap dyno numbers
Old May 15, 2013 | 12:20 PM
dick_landy's Avatar
What was your before boost and then after with the cam and pulley swap? Also what is your alky kits gain **** set on? The **** that goes from 1-10.
9 psi before with the 3.65" pulley, 9-10 now with a 3.25" pulley, cam and 4" exhaust. Haven't really played with the meth too much yet. AFR is 11.3 on pump 91. When road testing it i found an issue with 2nd gear so thats being looked at now. Basically at wide open throttle and the tires are spinning the gear disengages. It's not flaring but more like the solenoids putting in in neutral and it only happens between 35-4500 rpm in 2nd. All my dyno pulls are made in 4th gear on a mustang dyno, when the motor is around 90*f and make a pull on the dyno it will hover around the 505 mark but when hot it's back to back 486. Once I get the trans tune sorted out I'll start looking at the meth.
Old May 15, 2013 | 12:22 PM
03sierraslt's Avatar
11.3 AFR with the meth? If so do you know how much timing you were seeing?
Old May 15, 2013 | 12:36 PM
dick_landy's Avatar
Without. I really don't know much more about the tune than that. I just leave it with the shop that's doing the tuning while I go make money lol
Old May 15, 2013 | 03:35 PM
oakley6575's Avatar
If you spray a decent amount of meth and do not tune for it then it will be way too rich and loose power.
Well the truck was on the dyno with the tuner.. I thought it was implied that the tuner would tune for the extra fuel
Old May 15, 2013 | 04:16 PM
I took it as though at the end they turned it on for a pull but didnt tune for it. IDK?
Old May 15, 2013 | 05:20 PM
dick_landy's Avatar
Correct! Tuned it for gas first.
Old May 18, 2013 | 04:23 PM
dick_landy's Avatar
Even with this little hiccup i managed 1.96 60' 12.61@111.35
Last year I ran 12.4@ 110 with a 1.71 60'
6L80E Issue - YouTube
Old May 18, 2013 | 05:20 PM
$ierraLY5's Avatar
What accessory belt are you running, 6 rib or 8 rib? I can't tell watching the video but it looks like an 8 rib.Last week I put the 3.25" pulley on mine with a new, shorter, Gates 6 rib and I had to tighten the hell out of my mechanical belt tensioner to stop it from slipping.
Old May 18, 2013 | 05:49 PM
dick_landy's Avatar
6 rib. I went back to the stock tensioner and use a ford excursion diesel belt with 2 ribs cut off. It works pretty good and occasionally I hear a chirp when I downshift and punch it but that's it. Been like that for a year now.
Old May 27, 2013 | 06:07 PM
dick_landy's Avatar
Problem solved. I guess with all the torque now the header would press on the starter wire and eventually burned through causing it to ground out whenever I had good traction. I noticed it when I was installing the caltracs and fixed it. Hauls *** now!
