Should I be running different plugs with a 6.2L @ 8psi
#31
Ill use the standard plugs. I can afford to replace them when they need to be. As far as gapping them The shorter the easier it is on the ignition? .030-.035 should I just run all of the anywhere in between? will it mater? all the same gap of course.
#32
It's not really recommended to gap a platinum or iridium plug, you can really screw em up if you're not extremely careful. Sorry your thread got kinda out of hand on a spark plug debate vs what you were trying to decide for your own truck. For the price, track record and ease of changing gaps I'd run the br6ef ngk plugs for your setup and as stated before between a .030-.035 gap. You can pick them up at any local parts store for $1.99 a plug.
05GMC4.8
Aug 7, 2015 09:55 PM
Nimoryan
Jul 5, 2015 03:50 PM
