Should I do Meth?
Old Apr 6, 2013 | 01:42 PM
^ is that for real?
Old Apr 6, 2013 | 03:59 PM
RandomHero's Avatar
Got hotter from 30 to 31
Became a lesbian at 32
Went on the Paleo Diet from 33 to 34
Became Chinese at 37
I'd say that woman lived a full life.
Old Apr 6, 2013 | 04:04 PM
Mangled03gmc's Avatar
Baltimore Whore
I'd hit it.
Old Apr 6, 2013 | 04:25 PM
asap216's Avatar
I'd hit it.
X2
Old Apr 6, 2013 | 05:03 PM
Koots's Avatar
It seems pretty obvious that she went full prostitute at 31, then she became a lesbian, for even more obvious reasons after that.
Old Apr 8, 2013 | 02:41 PM
11silverado's Avatar
back to methanol talk ..
in my experience unless you upgrade your internals anything beyond 8lbs of boost on a stock 5.3 is risking pistons breaking, etc (meth or no meth). I know plenty of guys running 10lbs but I consider it borrowed time..
And i would recommend meth not matter what boost you are running ...look up a kit that comes with everything so you dont have put it together ..the alkycontrol (or simliar) kits are great, they come with tank, controller, pump, etc. i personally use pure meth / no water..
Old Apr 8, 2013 | 03:24 PM
Ferocity02's Avatar
I know some windshield washer fluids are part methanol, up to 50% for the -40F stuff. Is this stuff safe for use with the stock washer fluid tank, pump, lines, etc? Apparently methanol can be pretty corrosive. Will it damage paint?
Old Apr 8, 2013 | 03:35 PM
Atomic's Avatar
I have a gauge for that
Ive had mine filled with 100% methanol for about 2 years and its fine.
Old Apr 8, 2013 | 03:36 PM
nonnieselman's Avatar
If you leave it on then it will damage paint.. but just dont spill it
Ive been using -20* WWF and its ~35-38% methanol. and 10psi isnt on borrowed time unless its with a bad tune. Ive gone 25psi too many times 85# injectors were 150% haha..
You can start out using -40 if you can find it.. -20 is the lowest i can find here. ill go straight methanol for the track.. but im very rarely over 6psi dail driving and towing.
Old Apr 8, 2013 | 03:48 PM
Denali08's Avatar
You will need more than 15 psi to get 600rwhp.
Numbers are in my signature is at 15 psi and I have 348ci engine. 91 octane tune.
