SCOL ported blower snout
Old Jan 14, 2020 | 10:17 AM
terravast4's Avatar
while this is most likely true, the throttlebody doesn’t know boost. Only airflow, so that’s the main factor.
i do not disagree with you but there is an obvious air flow difference between 6, 10, 14 and 17psi and above. I am just stating what i have read from others experiences.
Old Jan 14, 2020 | 12:35 PM
03sierraslt's Avatar
only if you compare on the same engine. A 408 at 10psi flows more air then a 4.8 at 18, that’s my point. It doesn’t know boost, only mass air volume. I would bet it’s more relatable to blower rpm than any other factor.
Old Jan 14, 2020 | 02:05 PM
terravast4's Avatar
yep!! You hit on the head.
Old Apr 10, 2020 | 03:01 PM
BlownChevy's Avatar
blownerator
25 Year Member
Old Apr 10, 2020 | 03:05 PM
dantheman1540's Avatar
Hows this thing been going? I already want to pulley down more on mine.
Old Apr 11, 2020 | 12:51 PM
terravast4's Avatar
have not done the install just yet. I will post up when it gets done
Old Feb 2, 2021 | 10:07 AM
terravast4's Avatar
Update: I finally got around to installing the SCOL ported snout, The Nick Williams 102mm boosted throttle body. I also pulled down from a 2.8 pulley to a 2.7 pulley. I saw a gain of 5 psi for a total of 15 psi. made a huge difference and the blower is super responsive now. cant wait to hit the track.
Old Feb 2, 2021 | 03:00 PM
BigKID's Avatar
Those are excellent results!
By my calculations (which make some rough assumptions about engine VE) from where you were with the 2.8 pulley, the 2.7 alone should have given you just shy of a pound extra. Extrapolating from that, the ported inlet and throttle body increased blower efficiency 11.5%. This really makes me want to work on the inlet track of the KB once I get the new suspension sorted out.
Just curious, what size is the inlet track up to the throttle body?
Old Feb 2, 2021 | 04:24 PM
terravast4's Avatar
the intake is 5”. I bought it from a forum member last year.
Old Feb 2, 2021 | 07:31 PM
Looking good.
