school me on FI cams
Old Dec 18, 2010 | 12:50 PM
454navyss's Avatar
Default school me on FI cams
How do i tell what a good FI cam is? Just from what i have gathered, a close split duration, big lift and a large LSA, am i right? I am thinking about an iron block ls1, 317 heads with a 76mm turbo and want to pick a nice big(ish) cam for it, not over about .600" lift though. give me some numbers to think about. Thanks
Old Dec 18, 2010 | 12:58 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Duration has much more bearing on power than lift does. Also its overlap that matters with FI cams not just the split and lsa. More overlap is a direct byproduct of a wide lsa.
Old Dec 18, 2010 | 01:00 PM
MikeGyver's Avatar
You don't need big lift, you don't want overlap (that's why the "large" lsa), and the big-ishness is only according to what rpm you want peak HP at.
Old Dec 18, 2010 | 01:02 PM
MikeGyver's Avatar
You meant to say "less overlap".
Old Dec 18, 2010 | 01:04 PM
454navyss's Avatar
I will probably only turn it to 7K or so, maybe a hair more
Old Dec 18, 2010 | 01:26 PM
MikeGyver's Avatar
Then yes, you will need a big(ish) cam. Sorry to be of no help.
Old Dec 18, 2010 | 07:44 PM
old motorhead's Avatar
[QUOTE=454navyss;4598777]How do i tell what a good FI cam is?
You quite simply run it by Pat G and see what he thinks. The best 25 bucks you'll ever spend.....other than if you catch Glenlivet scotch on sale...
Old Dec 18, 2010 | 08:59 PM
Why not 226/230 114lsa with .600 lift on both sides? 0 overlap, should sound mean with low idle speed, and should make enough power on mild boost to break lots of sheet. Keep this quiet....it's a "secret" grind....
Old Dec 18, 2010 | 09:14 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What about reverse spit cams for turbo, they used to be very popular, no?
Old Dec 18, 2010 | 09:27 PM
That kinda gets back to the match between turbo, vehicle weight, manny/auto tranny, gear ratio, boost level, etc. Makes me want to get the input of a pro. Reverse split cams are a tough sell. How many cams have you seen with more duration on the exhaust side? N/a, s/c, turbo. Maybe a custom grind, but you'll be hard pressed to find an off the shelf grind with more on the intake side////? It might be better, but we're too dumb to know.
