s475 w/ 1.10 t4 on lq4?
im working on my 6.0 swap in my 91 mustang GT, and was wondering how well the 1.10 t4 hotside would work on the 6.0
i have the turbo already and was planning on using it on my h/c/i 302 that was in the car, but decided a lsx would be more fun
the 6.0 will be a stock longblock with probably a texas speed torquer v.2 or similar cam, and a carb blow thru setup, im not worried about it spooling fast, more worried about running outta steam up top
id like to see 550-600rwhp
No, not at all even with the smallest turbine wheel you can get on that turbo which is a 83mm, It will still feed the 6L just fine. That's enough turbo to support probable 700+ on a 6L it you really crank it up!
The base unit that turbo is built with is used on 14L Detroit Diesel engines. It's a big turbo
How do I change this text
calsdad
Jun 14, 2023 11:07 PM
