S/C Build, Need some suggestions
Old May 21, 2013 | 06:44 AM
damianldaigle's Avatar
Default S/C Build, Need some suggestions
The run down:
2009 GMC Sierra 1500 4x4 CrewCab 5.3 My current mods are American Racing headers w/ y-pipe and no cats, Dynomax catback and Volant Power Core CAI.
Sitting on the shelf I have a MP112 SuperCharger and Lingenfelter GT2-3 cam. When I get it tuned they'll port my throttle body.
The questions:
I'm ready to begin the upgrade and will have my heads ported since they have to be removed to install the cam. I was leaning toward Lingenfelter for this also, are there any other highly reputable porters that without a doubt give me better results?
Injectors, 60lb sufficient? Any particular brand to stay away from?
Are there any other engine related odd and ends I should consider while its apart, I'll address drive train later.
What is the smallest size pulley I can safely run and approximate boost? I ordered the 1" phenolic spacer also which should help IAT's with a killer chiller planned for the near future.
Thanks in advance
Old May 21, 2013 | 09:24 AM
Anyone? Also, will my stock pump be sufficient for this setup?
Old May 21, 2013 | 09:37 AM
TX Tahoe Z71's Avatar
Heads do not need to be removed for a cam swap.
I'm at 10psi with a 3.0" pulley with my mp112, gt2-3 cam and catless LTs.
Stock fuel pump will probably not be sufficient.
I would replace the timing chain with an LS2 while you're in there. Also buy new timing cover and coolant passage gaskets and a new crank seal, cheap insurance against leaks.
Old May 21, 2013 | 01:13 PM
Yes the heads will need to be removed in order to delete the DOD. The engine is an LS2. The charger has a 2.8" installed but was previously used on a 6.0 with a large cam. I'm thinking that may be a bit much for the 5.3
Old May 21, 2013 | 01:34 PM
Forgot you had dod.
Rule of thumb for these is 1psi per .1" drop in pulley size. I am on the edge of blowing through my maf, so if I went any smaller, if have to go speed density tune. Don't know about nnbs, might be different.
Old May 21, 2013 | 02:20 PM
5.3 isnt an ls2. u are right about the dod and head removal.
Old May 21, 2013 | 02:29 PM
JCunningham's Avatar
is it a flex fuel pump? if so it will be good.
Old May 22, 2013 | 08:16 AM
Originally Posted by TX Tahoe Z71
Forgot you had dod.
nnbs? Not familiar with the lingo yet. Ill prolly go with a 3.0 pulley also, I'm worried about longevity running the 2.8.
Old May 22, 2013 | 08:18 AM
Forgot you had dod.
Negative, how much power can the flex fuel pump handle? What would be better the flex fuel pump or a walboro 255?
Old May 22, 2013 | 08:43 AM
KHester84's Avatar
I remember smokeshow saying his non flex-fuel NNBS pump handled close to 600 rwhp, any others running a stock NNBS pump with boost?
