RX Catch Can 6.2l Magnuson
Old Apr 6, 2016 | 09:05 PM
sledaction 198's Avatar
Default RX Catch Can 6.2l Magnuson
I recently installed my RX catch can on my 2010 Silverado 6.2l with a magnuson. And ideas what I should do with the other port on the catch can. As of now I just put a nipple on it.
Attached Thumbnails RX Catch Can 6.2l Magnuson-20160406_191714.jpg   RX Catch Can 6.2l Magnuson-20160406_191722.jpg   RX Catch Can 6.2l Magnuson-20160406_191727.jpg
Old Apr 7, 2016 | 05:02 AM
blown02408's Avatar
02 w/ lowest mileage 2800
That can looks familiar, lol. You basically have three options; cap it like you did, remove the valve and plug it (the valve is just threaded in), or run another line pre throttle body ( redundant but it will work fine). With the dual valve can your all set if you ever decide to change forced induction.
Old Apr 7, 2016 | 07:16 AM
Catch can worked great and in perfect condition. Thank you Blown02408!!!!
I was thinking about running the other port over to the intake port cap off my clean side valve cover. Then run a vented oil cap.
Old Apr 7, 2016 | 07:23 PM
blown02408's Avatar
Awesome, glad to hear it!!!
Does your truck still have a MAF sensor? With the oil cap breather you could allow unmetered air into the engine.
Old Apr 7, 2016 | 10:41 PM
Vortec350ss's Avatar
Looks awesome!!
Also looks like your intake tube is too small. I'd want a 4" intake.
Old Apr 12, 2016 | 09:44 PM
1bad2k's Avatar
Looks good! I need to install mine, but mine is single valve so I was going to run from back of driver side vc to can, then out to the back of the j tube on my mp112. Did you put a breather on your oil fill tube? Is that needed?
Old Apr 14, 2016 | 12:16 PM
Looks awesome!!
Yes that is true. I am putting a 4" intake on when I put the ported ls3 TB on. I have a number of things going on the truck this weekend.
BigBlock90
34
Apr 20, 2016 12:48 PM
01SilveradoJakee
Apr 19, 2016 06:30 AM
FamilyTruckster
Apr 11, 2016 08:15 PM
02Sierra2500hd
Apr 5, 2016 08:22 AM
BruiSSer
Apr 2, 2016 09:27 PM
