Running out of fuel
Old Apr 29, 2008 | 01:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by BigCountryx
where's the best place to get a new FPR? Dealer........Anyone got a part number by chance?
double check my part number:17113536
I would try to remove and reinstall the old one first.....make sure all the the o-rings are intact and lubed up like a virgin on prom night.
If you can tell me what your FP is with the key on and the engine off I can tell you if it is bad.
Old Apr 29, 2008 | 01:45 PM
BlownChevy's Avatar
blownerator
25 Year Member
rear drivers side nipple by the MAP?
Yep
That's where it's running from. Is there a problem with having my boost gauge tee'd into that line?
Nope
Old Apr 29, 2008 | 01:56 PM
BigCountryx's Avatar
OK I'll check that out when I get off work......You want me to jumper out my relay so the gauge stays on, then kill my truck?
What should the pressure do and what shouldn't it do?
Part Number description from GMParts direct
GM PART # 17113536 *
CATEGORY: Fuel Injection Hardware
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $138.49
OUR PRICE: $72.02
DESCRIPTION: Fuel Pressure Regulator Kit
(1st design with vacuum tube out side of regulator cover)
Also used on 502 RamJet crate engine
For 2nd design see 17113700
GM PART # 17113700
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $102.81
OUR PRICE: $53.47
DESCRIPTION: REG KIT
(2nd design with vacuum tube out top of regulator cover)
Old Apr 29, 2008 | 03:05 PM
If I left off the smallest O-ring, the one on the tip, would that cause the problem that I'm seeing. I'm trying to remember, but I think I may have left that one off, that is if this pic is acurate....... Can't wait to get home to check. aaarrrrrrg
Old Apr 29, 2008 | 03:08 PM
thunder550's Avatar
High on diesel fumes
All you should have to do is turn the ignition on without starting the engine to let the fuel pump prime.
Old Apr 29, 2008 | 03:19 PM
OK, gotcha
Old Apr 29, 2008 | 03:21 PM
BlownChevy's Avatar
blownerator
25 Year Member
if you left that o-ring off, that is your problem.
Old Apr 29, 2008 | 03:24 PM
Superado's Avatar
11 Second Truck Club
listed for my 2000 w/ return system...as well as your 2003...
@ O'Reilly:
BWD AUTOMOTIVE - New Pressure Regulator
Item No: 24027
$55.99 Each
1 Per Vehicle
1 year limited warranty
OE# 17113555
Old Apr 29, 2008 | 03:29 PM
Thanks guys, I sure hope it's something this simple...........
Old Apr 29, 2008 | 09:09 PM
Whippled 496's Avatar
Start at post 63.....
https://www.performancetrucks.net/fo...=378174&page=2
