return system
Old Apr 29, 2011 | 10:40 AM
  #21
Mangled03gmc's Avatar
Baltimore Whore
So what FPR are you running if your feeding the rails directly from the pump??
Old Apr 29, 2011 | 01:10 PM
  #22
Sinr98's Avatar
Aeromotive A1000 boost ref reg. Has 8an inlet and 6an return. My fuel pressure sending unit will be mounted in the fitting after the fuel filter. This way I can monitor the fuel pressure to the rails and if something happens I can get out of it sooner. With the reg after the rails it allows the pressure (58psi out of boost, and 1:1 in boost) to stay consistant at that pressure. If the reg is before the rails it can bleed off pressure in the rails from the rate of fuel consumption and not be as steady in boost. Basically you would be putting a restrictor on the fuel pump. With this set up you are keeping the pressure at the rails and returning what fuel isn't needed to the tank.
This is pretty much how i'm doing the system. Under the A1000 set up. http://aeromotiveinc.com/wp-content/...werPlanner.pdf
If you notice, the reg is after the rails, and returns to the tank.
Old Apr 29, 2011 | 03:39 PM
  #23
KDavis04ss's Avatar
Originally Posted by Sinr98
Here is a drawing I did of my set up i'm working on. Single Aeromotive 340 in tank, with stock feed line to the rails with 8an hose and fittings. Return will be from the Aeromotive fpr 6an to the tank with a bulkhead on top of the tank. Holes will be drilled in the bucket along the bottom to keep it full. there is a in line fuel filter that will be used right after the feed line and before the y-block.
I had to scale the pic to fit on here so the details in the writing are hard to read. Also it's just a vague layout to get the visual of it. I did it in CAD so I had to scan the drawing then change the files for it.
Could you email that to me KyleDavis89@gmail.com
Old Apr 29, 2011 | 04:11 PM
  #24
KDavis04ss's Avatar
Originally Posted by 1989k1500
You can also y it before the rails, feed each rail, then come out of each rail into the fpr, then a return line out of the fpr.
Is this what your talking about?
Old Apr 29, 2011 | 06:08 PM
  #25
1989k1500's Avatar
yessir
Old Apr 30, 2011 | 10:05 AM
  #26
ALL ULL C's Avatar
Just an FYI, you won't need the Y-fitting coming out of the front of the rails. The EFI A1000 has 2 inlets (from front of rails) and 1 outlet (back to tank)
Old Apr 30, 2011 | 05:05 PM
  #27
KDavis04ss's Avatar
Thanks man. Is that about one of the best regulators to go with?
Old Apr 30, 2011 | 06:57 PM
  #28
ALL ULL C's Avatar
I would say they are pretty common, you'll be looking for P/N 13109.
Old Apr 30, 2011 | 08:14 PM
  #29
Pocket's Avatar
The first sketch will work fine for ALOT of power
Any reason you think you need -8 of -6? -6 will flow a TON of fuel and is much more common/inexpensive
Running the rails in parallel isnt required either. As stated above, if you're worrying about uneven fuel distribution, upgrade the pump
Old Apr 30, 2011 | 08:35 PM
  #30
Baltimore Whore
I still would like to see a or hear of a issue with running the fuel system like I had said?? You are still getting a FP rating from the FPR or rail.. Once it is pressurized it should stay that way..
Pimpinpete
43
Dec 22, 2017 08:13 AM
TAPyvehc93
Jan 8, 2016 10:47 AM
turbo6c3
Oct 5, 2015 06:11 PM
Slammed silverado
Sep 28, 2015 06:14 PM
97_ek
Sep 23, 2015 09:16 PM
