Relocate IAT Sensor
Old Aug 29, 2005 | 10:19 PM
rosscob's Avatar
Default Relocate IAT Sensor
I wanted to relocate my IAT sensor from the MAF to the boosted side of the whipple. Has any one done this? Where did you get the sensor? Where did you locate the sensor? How did you wire it?
I think it would be easier to tune this truck if I had some accurate IAT readings.
Thanks
Old Aug 29, 2005 | 10:31 PM
02sierraz71_5.3's Avatar
the iat that is integrated/used by the pcm is part of the maf you'd have to buy an after market sensor
Old Aug 29, 2005 | 10:37 PM
rosscob's Avatar
Can you use one out of a camaro or firebird?
Old Aug 29, 2005 | 10:45 PM
Searching4Sierra's Avatar
i ripped one off of an s-10 (same as camaro), and tapped into two wires on the MAF, and mounted it a little bit before my TB.
Old Aug 30, 2005 | 01:35 AM
Mike Oxlong's Avatar
I want to do that as well. I heard that there was a kit you can buy but I haven't been able to find it.
Old Aug 30, 2005 | 04:18 AM
onyx's Avatar
14 Second Truck Club
i bought an IAT sensor from the dealer. im going to go out in the garage and find it and see if there is a part number on it. then there are 2 wires you can cut from the MAF and splice them into the sensor.
Old Aug 30, 2005 | 04:21 AM
onyx's Avatar
ok found it...
part # 12160244
Old Aug 30, 2005 | 09:01 AM
Mort's Avatar
Cool
I used an IAT sensor out of a 97 Camaro I believe. It is the same part # as onyx used. I also got a waterproof connector for it and a grommet from a brake booster vacuum connection to mount it in the intake tube. I actually used a similar grommet I got for my STS methanol injection kit and swapped it with the GM grommet but I am sure the GM grommet could be made to work.
GM IAT Sensor #12160244 $20.36CDN
GM Connector #12102620 $25.56CDN
GM Grommet # 12338042 $7.64CDN
I got the information for this install from Jerry2500 in this thread.
Old Aug 30, 2005 | 09:51 AM
Wilde Racing's Avatar
How do I change this text
I wanted to do this mod, but thought I read some-where, that it will make the MAF readings way out of spec because the temps will be colder (more dense) (sp) than what the MAF is "seeing" (less dense). Any input on this?
Old Aug 30, 2005 | 11:04 AM
Ive never done it but I should think you could compensate for anything like that by recalibrating the maf table.
