Reasonable price for pulley and meth
Old Jan 14, 2011 | 05:00 PM
renaldo99's Avatar
Default Reasonable price for pulley and meth
i was woundering is $2200 reasonable for a meth system with 2gal tank/install, smaller pulley/install, new belt & re-tune?
Old Jan 14, 2011 | 05:44 PM
03sierraslt's Avatar
Thats high, at least to me.
Old Jan 14, 2011 | 06:18 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Yes.
Meth kit (top of the line) installed $800
Pulley $100 (maybe a bit more if a RIP pulley)
Belt $25
Install belt/Pulley $50 (maybe!)
Re-tune *$400
*If it's the place that did your original tune then $400 is pretty A re-tune for meth and a pulley should be $250 or so I think. If you didn’t get your original tune there then I can see $400 to $600 depending on if you're are doing MAF or SD.
I think the prices above are pretty generous so if you aren't getting out the door for under $1600 tax and all, I'd probably keep looking.
Old Jan 14, 2011 | 06:30 PM
kbracing96's Avatar
Is the shop familiar with your truck? I see you have a Roush TVS1900 with the pressed on pulley. If that includes pulling the snout off the blower and doing all the necessary custom machine work to go with a smaller pulley, then might not be to bad of a price. Still kinda high, depends on there labor rate.
If they think there gonna pull the pulley off that blower and just put a new smaller one on it they are mistaking and WAY over charging for that.
Old Jan 14, 2011 | 06:54 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
depends on how big the bag of meth is really and if they weigh it with the bag or not...
and remember your local dealer is not always the cheapest
Old Jan 14, 2011 | 06:59 PM
TX Tahoe Z71's Avatar
Originally Posted by 1SlowHoe
Yes.
Belt $25
Re-tune *$400
+1 But yeah, the Roush pullies are press on and the snout must be machined to change pullies (do a search, there are a few threads about this).
Go with a Devils Own or Alky Control meth kit, use your existing washer fluid tank since it has a low level sensor built in so you will know and won't burn up your motor if you are running too low on meth. Gates belts are top notch. And the tuners on here are top notch too
Old Jan 14, 2011 | 08:51 PM
renaldo99's Avatar
Yeah he knows what i have because he did my tune.. He said he has to take out the pulley send it out to get a custom make pulley because roush stopped making the s/c...
The meth kit is gonna be a alky and he also said hes gotta get a 2 gal tank which doesnt come with the kit..
Old Jan 14, 2011 | 09:26 PM
1SlowHoe's Avatar
How much meth does he think you need to spray? 2 Gallons is a ton of meth. I have a 1 gallon tank in my GTO and havent gone through that in months. Where does he plan to mount this tank?
Ask him for a quote minus the pulley change and see what he says. Then decide if that extra pound or two is worth the cost right now.
Old Jan 14, 2011 | 10:24 PM
renaldo99's Avatar
he said my set up sucks more meth so thats why i need a 2gal and he also said for the part its gonna be around $500 and almost $600 to install ..
My Tahoe is a Daily Driver
Old Jan 14, 2011 | 10:30 PM
600 to install?!?! Wow, he takes pride in his work I guess.
