Re-arranged my throttle bodies.......
Old Apr 18, 2010 | 12:38 PM
DrX's Avatar
DrX
Originally Posted by TurboGibbs
Looks great! Those 2 TB's will make that throttle response extremely sensative. But, you should be able to slow the low speed opening rate enough can't you? The "Max rotation vs peddle" in HPT is what I was thinking of. Never messed with it though.
EFILive has a warning about tweaking that table more than a few % resulting in a fried PCM, but it looks like some have made significant changes. I wouldn't think that decreasing the pedal response would an issue.
Old Apr 18, 2010 | 01:35 PM
00chevsilv's Avatar
Looks great. Are you going to be throwing on a different hood/scoop or just modifying this one to cover everything?
Heard you hammer on it once yesterday on the perimeter when I was on the golf course but I guess the belts explains why it was only once lol. Sounds sick even from a half mile away. Hope to see it in person some time this summer.
Old Apr 18, 2010 | 07:07 PM
DrX's Avatar
DrX
This scoop is just to hide the hole.....or most of it. I want a custom steel scoop designed to restore rigidity to the hood. May even start with a fresh hood. I am just using the original hood as a template.
Old Apr 18, 2010 | 07:32 PM
DrX's Avatar
DrX
BTW, I fixed the throttle shutting down on its own issue today(tune) but I took out all 3 belts in one shot when I let out of the throttle. Wasn't an issue before I put on the 3.0 pulleys. Yes, I went to a tighter belt - tightest I can get on. That was a mess on the side of the highway with no spare main accessory belt in the back and belt spaghetti wrapped around everything.
I wasn't too kind to the Nitto 305's either.
Guess I will just need a set of belts for every pass down the 1/4!
Belt Shredding Vid:
Old Apr 18, 2010 | 07:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Any idea whats causing the belt shredding issue?
Old Apr 18, 2010 | 07:49 PM
DrX's Avatar
DrX
Not yet. Need a belt cam.
Blower RPM dropping faster than the crank RPM?
Also looks like the blower tensioner pulley is pretty close to the idler pulley with the idler at minimum stop. If the belt ever gets that loose it might catch on itself?? Might try repositioning one of those.
Will see what the log tells me re RPMs, etc.
Old Apr 18, 2010 | 08:28 PM
SILVERADO11's Avatar
love your build DrX, its nice to see someone build something different. good luck with the belt shredding issue
Old Apr 18, 2010 | 09:02 PM
allballz57's Avatar
Looked like you were having fun before the belt gave out!
Old Apr 18, 2010 | 10:40 PM
BlownChevy's Avatar
blownerator
25 Year Member
Where did you get that fancy adapter for the 90mm DBW throttle body?
Old Apr 18, 2010 | 10:41 PM
1slow01Z71's Avatar
Edelbrock
