Random smoke out exhaust after turbo
Old Dec 25, 2014 | 02:46 PM
zaathur151's Avatar
Default Random smoke out exhaust after turbo
I just swapped in a lq9 with new rings and bearings and a trick turbo kit with 74mm precision turbo the first 3 days I had no smoke just a little at first tell I deleted factory pvc and just vented both valve covers then was fine, then today when I drive around it will randomly have grey smoke out exhaust then stop then come back any ideas it gets really bad when I am moving slow or backing up?
Old Dec 25, 2014 | 04:31 PM
zaathur151's Avatar
Note this truck just has a base mail tune on it also
Old Jan 30, 2015 | 10:38 AM
sevenTcamaro's Avatar
Have you found the issue yet as I'm having the same problem but mostly on deceleration, same kit as yours with 74/75 precision, iv been told it's the drain going into the front of the pan.
Old Jan 30, 2015 | 10:59 AM
zaathur151's Avatar
Mine stopped after I found gasket maker in the return line
Old Jan 30, 2015 | 11:27 AM
Atomic's Avatar
I have a gauge for that
Turbo smoking is almost always due to a problem with the drain line. Either clogged, not steep enough (if its a gravity drain), or too small of a hose.
Old Jan 30, 2015 | 02:31 PM
thunder550's Avatar
High on diesel fumes
Other possibility is if it's a ball bearing turbo without a restrictor in the feed line. Ball bearing turbos often can't handle the same pressure that a journal bearing turbo can.
Old Jan 30, 2015 | 02:40 PM
George C....'s Avatar
Formerly ScreamingL
Or other possibility is the tune was and you clipped a piston
05GMC4.8
Aug 7, 2015 09:55 PM
Three6GMC
Aug 3, 2015 07:53 PM
4B11T
Jul 13, 2015 03:48 PM
rojeho
Jul 12, 2015 06:10 PM
03sierraslt
Jul 11, 2015 02:47 PM
