Random smoke out exhaust after turbo
I just swapped in a lq9 with new rings and bearings and a trick turbo kit with 74mm precision turbo the first 3 days I had no smoke just a little at first tell I deleted factory pvc and just vented both valve covers then was fine, then today when I drive around it will randomly have grey smoke out exhaust then stop then come back any ideas it gets really bad when I am moving slow or backing up?
Other possibility is if it's a ball bearing turbo without a restrictor in the feed line. Ball bearing turbos often can't handle the same pressure that a journal bearing turbo can.
05GMC4.8
Aug 7, 2015 09:55 PM
Three6GMC
Aug 3, 2015 07:53 PM
