Ran truck for first time at track.. Disapointed!
Old Oct 29, 2012 | 02:13 PM
  #41
ZO6Ted's Avatar
Originally Posted by patofdzb
I will go to napa and order some BR7EFs, no one here has those in stock.
My boost/vac gauge and BOV are referenced through the Intake manifold nipple.
My valve springs are Yellow LS6, not the stock ones.
Im going to give it some last trys with justin, hope we can get it right, he seems to think it might be that my maf is being fooled (SEE PICTURES)
He says my maf is reading about 19 psi of boost.. but im only doing about 13, so its putting in way more gas and pulling timing. He told me to rotate my MAF 90º and see if that changes anything...
P.S. My MAF was pushed off the housing while doing a highway pull, so i put that huge zip tie around it to prevent it from happening again
Sorry I said stock but didn't clarify. Some have still floated the yellows and ZO6 cam with boost over 8 or so lbs. Some have not depending on rpm.
Old Oct 29, 2012 | 11:48 PM
  #42
patofdzb's Avatar
ok well it seems like will go with an SD tune.. will a 2 bar map be fine?
i do plan on swapping my valvesprings, but in a little while.. i want to swap my 80e first
Old Oct 30, 2012 | 10:18 AM
  #43
yea 2 bar will work just fine
Old Oct 30, 2012 | 10:11 PM
  #44
bajachevy37's Avatar
i would get some kind of vacuum back on the heads.. my 5.3 didn't come with the egr we put and aftermarket one on their to get ring seal. saw 10hp at the wheels difference because of it
Old Oct 31, 2012 | 04:28 PM
  #45
custom 68's Avatar
I was MAF and had all kinds of problems but mine is tucked in my 68 pickup. I am working on the SD tune right now and it sure makes a world of difference in mine. Again my cold piping had some bends in it around the MAF causing it to freak out. Alot of people still run teh MAF with the turbo.
Old Nov 1, 2012 | 11:32 AM
  #46
La Chochita's Avatar
I agree theres nothing better than an in person dyno tune.. but sadly thats not possible..
Tuning is done via AutoCal...
I also noticed that 3rd gear, the truck just dies
Could be various things...maybe too rich on 3rd gear due to more load...or maybe ur iat's are goin high enough for the table to pull timing...unless they moved it.
Im still on MAF and is running great...its a bummer u dont have a good local tuner. Id have to agree with the majority here. U should learn to tune and that way ull have it dialed like U want it WHEN u want it.
Old Nov 1, 2012 | 11:43 AM
  #47
jjc839's Avatar
You're on MAF at 20psi and 790rwhp? Aftermarket I assume? Draw through or blow through?
Old Nov 1, 2012 | 11:47 AM
  #48
Llaverito's Avatar
Ive never had any problems with maf, if it was summer i could have tuned it for you over there, we make a trip every summer.
Old Nov 1, 2012 | 03:26 PM
  #49
No sir...still on my stock 03 MAF...blow through...its after the IC.
Old Nov 1, 2012 | 06:58 PM
  #50
patofdzb's Avatar
If possible i would like to stay on MAF, correct me if im wrong but some people have told me tune would be a little finer, and truck would have better idle, cold starts, etc. But right now, im just tired of my truck being this slow.
i would love to learn, but that involves another 700+ dlls for equipment, 3 weeks to get it over here, and then.. start learning
wrb002
Aug 31, 2015 12:00 PM
GMCtrk
Jul 17, 2015 06:39 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
