Radix on the way, few questions on details.
Old May 17, 2007 | 04:01 PM
Sambo53's Avatar
Default Radix on the way, few questions on details.
Hey guys, im kinda new on here but I'm also on gmfullsize and fullsizechevy. I recently purchased a Radix with the group purchase. Should be here in two weeks or so. I just have some questions about some other things to go along with it. I plan on getting a FLT level 5 4L70E tranny http://finishlinetrans.com/store/pro...products_id=31 I will be ordering the tranny after I get the supercharger installed. The stock tranny should be okay for a few weeks if I don't thrash on it too much correct? I am also planning on going with a new stall converter such as the Yank TT 2600. http://www.converter.cc/converters/truck/truck_main.htm It says 2600 stall with a stock 5.3, but I'm sure it will stall much higher with a supercharged 6.0L. I haven't spoke with the guys at yank yet but I'm just curious what do you guys think it will stall at? I don't want a stall too high because I do tow things from time to time with this truck. I would like to keep the stall around 2600 or so. I just want something to get me off the line a little harder, and I like the 2.1 STR also I also plan to get a bigger tranny cooler to go along with this too, I haven't looked into them much yet, any suggestions? For the gauges I would like to remove my stock cluster and get one with the tranny temp gauge to take care of that part, and I wanna run a triple gauge piller. I was thinking Boost, IAT, and A/F ratio. Does that sound about right or would you guys suggest I run something different, or more gauges? For the tune im gonna go with Nelson Performance and get a S & D tune since hes only 30 miles down the road from where I live and I have heard ALOT of good things about him and his shop. I also plan on getting a cam in this thing but thats a ways down the road. Do I need to change from the stock spark plugs or can I just use those? I have also read up on the thermostat and it seems I can just keep the stock thermostat and be fine. I know this is alot of questions at once but I have never owned, or installed a supercharger so I just wanna get as much info/ suggestions as I can so I can do this right. Edit: also forgot to add I do plan on putting a smaller pulley on to get more boost. Thanks for the help,
Sam
Old May 17, 2007 | 04:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The stock trans should hold with the stock Radix tune as long as you can resist beating on it. The FLT level 5 4L65e is what I run but I suggest you get a converter designed to hold the torque of the SC, like the SC series. My SC2800 flash stalls to 2800 and has a higher STR.
A Trans cooler is a good idea too. Click my sig, and look at my CarDomain pages.
Page 2 describes pretty much what you're looking at.
Old May 17, 2007 | 04:21 PM
Sambo53's Avatar
Yeah, I figured it would. I'm gonna have to try pretty hard to not beat on it. A 2800 stall would work just fine, thanks for the heads up on that I didn't think about it. Are you still able to tow some with that stall? I don't tow 10K or anything just mabye 4-5K every once in awhile and mabye 7-8K very rarely. What guages would you suggest I run? I have looked at your page before You have a badass ride man. My goal is some numbers like yours and some times like yours some day. I also forgot to add I would like to get a smaller pulley for more boost.
Old May 17, 2007 | 04:38 PM
trever1t's Avatar
I don't tow but i dont doubt that I could with the SC2800 if I wanted. The Yank converters are pretty tight.
Boost, fuel pressure and a Wide band O2 is what I have in the pillar pod. I swapped out clusters for the trans temp gauge too.
I would run the stock pulley for a while until you get those other mods in place. Welcome to the FI world, its a blast to have power at will.
Old May 17, 2007 | 04:43 PM
Sambo53's Avatar
Ahh ok. I will send yank and e-mail and ask them which converter they think will best suit my needs. I need to start looking for clusters too. I plan on swapping the pulley but not for awhile like ya said. Whats the stock boost, 5 or 6 psi? Thanks man, I have been saving for awhile now but its gonna be worth every penny. Can't let the diesel guys have all the fun.
Old May 18, 2007 | 02:18 AM
Spoolin's Avatar
GFYS and STFU
That new cluster will run ya 400+. Why not just run a 2 gauge pod up in the overhead as well as the pillar pod. You could throw in the tranny temp and fuel pressure and still be less than getting a whole new cluster.
Old May 18, 2007 | 06:56 AM
trever1t's Avatar
$400? Damn! Mine was $225 thru my dealer.......but I did have to return the core.
Old May 18, 2007 | 09:21 AM
dewmanshu's Avatar
Moderately Differentiated
I paid like 275 w/o core awhile back. I forgot where i got mine though. sorry for the no help.
Sounds like you have a plan! Call it a destructive plan. LOL Just kidding, seems you have done your research. I gotta admit, I would love an IAT gauge. Nothing to watch all the time, but I kinda like to know what they are. I think Brian@JPA is offering scan gauges for sell.
I am with terver1t, steps...take steps if you can afford it. Alot of my headaches where by doing everything at once.
Old May 18, 2007 | 12:38 PM
Spoolin's Avatar
GFYS and STFU
Sorry about that I shoulda mentioned I was referrring to the ones from Stylin Concepts. I was looking at buying one about two months ago but decided on a dual gauge pod w/ switches that goes in the overhead.
Old May 18, 2007 | 12:58 PM
SSThunder03's Avatar
With the LQ9 you should be hitting 5 psi with the stock 3.3 pulley. I've been told I can put on my 3.0 pulley and be alright for awhile(trans wise). Do you have any trans mods? I've got a shift kit/servos and a TBTC. It stalls around 2500-2600. When my trans goes I plan to add a FLT with a PI converter. Might as well spend the money on a good converter if you're going to spend the money on a built trans IMO. I run a boost, FP and wideband gauge in my setup. Those seem to be the guages most run.
