Radix vs.Trick vs. STS vs....
There are a lot of questions about STS vs. Radix, Radix vs. ATI, STS vs. Front mount turbo, etc., so this thread is a place to store all that info so we don't have to keep retyping it every time someone considers FI for their truck. I'll start out with my answers to these questions, which reflect my experiences and research (your mileage may vary so speak up), this is a sticky so we all have a common thread to that people can read at their leisure and so we can report new info.
Let me be the first in this thread to say that the best option for you depends on your goals, desires, targets, money, etc. There is no one-size-fits-all FI solution and there never will be because each method brings its own inherent strengths and weaknesses to the table. Almost ANY FI kit offers the potential of going stupid fast.
Here are my pros/cons for each system I thought of (some of this may be out of date, so PM me with details if you see something and I will correct my list):
STS : Squires Turbo Systems : Rear mount turbos
Strengths:
1. power potential -- turbos in general have more potential to make big horsepower, most of the time exceeding the engines capability to make power
2. Well designed kit (and being refined all the time)
3. Kit price is inexpensive, but the kit itself is incomplete if you want to make big power
4. No parasitic drag (although an argument has been made that the increased exhaust pressure effects the engine's efficiency)
5. Variable boost -- at the flip of a switch (with an upgrade to the basic kit), you can have 'everyday' boost and 'race' boost
6. Capability to grow with you as your goals grow
7. Easily modded
8. Doesn't require $1000 in exhaust parts to make max power
9. 1 year warranty
10. multiple intercooler options including air to air, air to water, meth/alky/water injection
Weaknesses:
1. kit requires welding / minor fabrication
2. kit needs more parts to make big power (see #3 above), but most are available from STS as options (injectors, tune, fuel pump, cooling method)
3. no boost until the turbo spools up (I'm not going to talk about lag here, as lag is generally misunderstood / or assumed to be the same thing as a turbocharged 4 cylinder's lag).
Trick Performance Products : INTRO / Street Stalker kits
Strengths:
1. HI front mount
2. Good price
3. All stainless steel construction for long life
4. 1 warranty on parts including welds and pipes
5. Easy to bolt in, NO CUTTING OR MODIFYING OF THE VEHICLE IS REQUIRED.
6. Quick Spooling
7. Upgradable to larger turbo, wastegates, blowoff valves.
8. User friendly changing spark plugs
9. A/C is not effected
10. Good starter kit for one that wants a HI front mount turbo kit.
11. Several Intercoolers to choose from depending on your application. Air to Air and Air to Water.
12. Drill and tap are included for oil return fitting that goes into the pan.
Weaknesses:
1. Kit requires a trip to the muffler shop for final exhaust connection (or a welder and 3' of tubing).
2. Intercooler available but not included in the kit.
3. Injectors, and tuning not included.
4. Not Carb. legal.
5. You have to drill and tap your oil pan for oil return.
6. You have to remove passenger side exhaust manifold and replace with new one.
7. Underhood temps may be slightly higher.
Trick Performance Products : Front Low Mount
Strengths:
1. Cost this kit is lowest cost turbo kit on the market today.
2. Coated mild steel pipes
3. Easy to bolt in, NO CUTTING OR MODIFYING OF THE VEHICLE IS REQUIRED.
4. Quick Spooling
6. User friendly changing spark plugs stock manifolds main in the stock locations.
7. A/C is not effected
8. Good starter kit for one that wants a LOW front mount turbo kit.
9. Intercooler is included (air/air)
10. Electric Oil pump included
Weaknesses:
1) Kit requires a trip to the muffler shop for final exhaust connection (or a welder and 3' of tubing).
2. Turbo and some piping hang just slightly below the chassis.
3) Injectors, and tuning not included.
4) Not Carb. legal.
5) fits a limited amount of trucks.
6) Lowered or slammed may not be able to use this kit.
Radix Magnacharger - Roots-hybrid supercharger
Strengths:
1. Instant torque -- any time, all the time
2. Intercooled
3. Very complete kit - intercooler, all necessary parts, pump included on 03 models
4. 'Easy' install -- no welding or fabrication, most people with basic wrenching skills can do this
5. Nice long warranty as long as you use the superchips tune -- 3 Year 36K mile Drivetrain warranty is additional cost ($200) and the install must be done by an ASE certified mechanic
6. Nice community support (Hey Brian!)
7. Someone weigh in here on customer support, but my feeling from talking to others is that it is STELLAR (comments from an owner: customer support is great, calls returned, you get to talk to technical people in the USA)
8. Great track record
9. Really shines at 7psi in terms of abidactic efficiency compared to similar style blowers (i.e. non-cent blowers)
Weakenesses:
1. Expense of the 'basic kit', which is probably the most complete FI
2. Ultimate power potential is limited, but limited to ~500hp which is enough for 95% of the world
3. Changing boost is more difficult than with turbos (pulley change)
4. Belt slippage with cheap belts (Gatorbacks seem to have no issues)
5. Needs full exhaust for maximum potential
6. Parasitic loss
Whipple - Twin Screw Supercharger
**note: these are all based on the Lysholm kits and all is subject to change with the new in house compressor**
Strengths:
1. Very high abidactic efficiency -- more than the radix according to the source (WHIPPLE...), but it is not really an apples to apples comparison. A/E is affected by ambient temp, and is pretty tightly coupled to the compressor variables -- so until we see data from a controlled test of similar boost levels in the same ambient conditions)
2. Complete kit
3. Instant torque from 1500 rpm up
4. In the upper rpms, this is probably more efficient than a radix
5. at ~15psi the abidactic efficiency is much better than the radix at the same boost (whereas 7psi vs 7psi the A/E favors the radix)
Weaknesses:
1. No intercooler
2. ECM is a piggy back system
3. Only comes with two add on injectors
4. Customer service leaves a lot on the table
5. No resale value -- Whipple requires s/cs to be evaluated and updated in order to flash the computer... I was told this always leads to at least $1500 in charges by a whipple employee
6. Parasitic loss
7. belt slippage
8. Needs full exhaust for maximum potential
9. pulley change to change boost
ATI - Procharger - Centrifugal Supercharger (most of this is old-- from my 5.0 days)
Strengths:
1. Higher power potential than Radix or Whipple, less than turbo
2. Great track record
3. Almost instant torque
4. Easy install
5. I've been told the cost of these has come way down to around $4k -- that's a good price
Weaknesses:
1. Kit needs more parts for maximum potential (injectors, intercooler -- although a FMIC is available from ATI as an option)
2. FMIC is not super efficient
3. Belt slippage requires special mounting brackets to turn up the boost
4. pulley change to change boost
5. Install is easy, but very involved.
6. Peak power only at shift point (these require impellor tip speed to make boost)
7. high parasitic loss
Vortech - Centrifugal Supercharger (5.0 days again)
Stregnths:
1. Same as ATI
2. Vortech has been around forever... Chances are if there is some problem with a centrifugal s/c, vortech not only has a solution, but invented the problem
3. Available air-to-water intercooler
4. LOTS of available options
5. Complete kit
6. Good support in general, but not much for GM trucks
Weaknesses:
1. Cost of the kit
2. Cost of maintenance
3. Peak power only at shift point (these require impellor tip speed to make boost)
4. high parasitic loss
5. belt slippage issues as boost increases
Detroit speedworks, PTK, CM, LM -- Front mount turbo kits
Strengths:
1. Like the Trick front mounts above, these have the most power potential of any FI option discussed here
2. The "in thing" in go fast
3. Since I am lumping several kits in here, I can't address the individual things of each kit, but generally speaking, these kits are complete, and ready to go
Weaknesses:
1. Underhood temps may be higher than with other options
2. May need heat reducing steps in addition to FMICs (depending on kit)
3. Since I am lumping several kits in here, I can't address the individual things of each kit, but generally speaking, may require extensive fabrication, loss of A/C, etc. (Cm and LM kits are designed to be bolt in)
4. Expense of the kit, plus install
I'd love it if you guys with front mount kits would either post up or send me the strengths/weakenesses and I'll edit them in for your particular kit.
Strengths:
7. Easily modded
9. 1 year warranty
Weaknesses:
Strengths:
1. HI front mount
2. Good price
6. Quick Spooling
Weaknesses:
4. Not Carb. legal.
Strengths:
4. Quick Spooling
Weaknesses:
4) Not Carb. legal.
Strengths:
2. Intercooled
Weakenesses:
6. Parasitic loss
Strengths:
2. Complete kit
Weaknesses:
1. No intercooler
6. Parasitic loss
7. belt slippage
Strengths:
4. Easy install
Weaknesses:
Stregnths:
1. Same as ATI
5. Complete kit
Weaknesses:
1. Cost of the kit
Strengths:
Weaknesses:
Last edited by TurboBerserker; Sep 9, 2012 at 12:31 AM. Reason: edited in Trick Performance Products descriptions
Awsome post
That is some really good info. I think this will help some new members or soon to be FI'd members make their decissions easier. Thanks for taking the time to do this
But you for got to tell them that STS is the Best
Very good post and excellent to build on.
There is no mention of parasitic drag for the Radix. Omission? Also none mentioned for the Centrifugal Superchargers. No big deal I was just wondering?
Congrats on getting green! First I noticed.
nice job on this. it seems very objective. i can add a little on the front mount.
"1. Underhood temps skyrocket
2. Need heat reducing steps in addition to FMICs
4. Expense of the kit, plus install"
the underhood temps do go up but after running the cmotorsports kit for a year or so i dont think any additional heat reducing steps are required. i did melt a section out of my wheel well but they have moved the waste gate since then.
the CM and LM kits both keep the AC and are designed to be bolt on kits. i dont know about the ptk stuff.
you might want to add something like increased liklyhood of exhaust leaks and higher maintainance like more frequent oil changes and synthetic being required.
Very good comparo. Im going be able to offer up some head to head challenges. Im going with a livernois kit with a bigger motor when I complretelywear out my vortech. Should be interesting.
Just to clarify Jim, did your kit come with any heat shields or anything like that? How about plug wire shields?
I was thinking about that clip of you manifold glowy cherry -- mine never glowed but they still set my plug wires on fire hehe
