radix/trans cooler
Old Jul 20, 2006 | 07:20 PM
gonzo 6.2's Avatar
Default radix/trans cooler
Hey radix guys were are you putting your trans cooler and not take away from the intercooler?How big can you fit one in?I want to bypass the radiator and go thru OE cooler.With a 28K truecool,thats what I am thinking.
Old Jul 20, 2006 | 07:42 PM
I mounted a custom intercooler below the bumper,went with a double pass aluminum radiator and mounted 2 big B&M supercoolers where the original intercooler was.100+ degree temps don't have much effect on my truck.
Old Jul 20, 2006 | 08:59 PM
BLASTER's Avatar
Added a bigger trans cooler
Old Jul 20, 2006 | 09:17 PM
gonzo 6.2's Avatar
great pics,what cooler?
Old Jul 20, 2006 | 09:32 PM
Whippled 496's Avatar
wow, thats blocking alot of radiator air. Any effects on the ECT's?
Old Jul 21, 2006 | 10:26 AM
David Cairns's Avatar
B&M trans cooler, still going through the radiator. Cut and re-arranged the stock hard lines. Flipped the Radix heat exhanger bracket around to be the lower mounting bracket, and fabricated the upper from some aluminum angle stock from the hardware store.
I moved the heat exchanger 'down stairs'
Electic fans on the Radix heat exchanger a big plus over the stock setup. The heat exchanger coolant will cool down a lot faster with them, especially when you are stopped at the light.
Old Jul 21, 2006 | 10:55 AM
gonzo 6.2's Avatar
very nice,thanks for posting.
Old Jul 21, 2006 | 09:42 PM
BLASTER's Avatar
Biggest B & M that Summit racing carried.
No adverse effects from blocking the radiator far as I could tell.
Really can't tell difference in the trans temp. but figured it had to help..
