RADIX Belt tensioner
Old Nov 20, 2006 | 11:33 AM
LBSBLOWN's Avatar
Default RADIX Belt tensioner
I raise my hood every day to service up the Meth so I see under there every day.
Anyways yesturday I noticed some belt dust and that is not the norm on my set up next I found that the belt jumped off the Belt tensioner by two ribs and that is what was causing the belt dust.
so I put the belt back on correctly which is dificult because of the spring tension of the tensioner is very strong so I know its not a week tensioner,
Anybodt eles seen this before?
and what do you think caused it?
Old Nov 20, 2006 | 06:57 PM
KySilverado's Avatar
I've broken mine twice. The belt jumping completely off. Never seen it just drop off a couple ribs. My belt jumps were both attributed to a hard pull with breaking traction and a quick back pedal.
Old Nov 20, 2006 | 07:29 PM
Bowtie70SS's Avatar
Never had mine jump off, I have broken 2 tensioners though. I wish there was a stronger one though.
Dave
Old Nov 20, 2006 | 07:36 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I've gone through.....5 I think. Always from a quick accelerate then let off the gas.
Old Nov 20, 2006 | 07:37 PM
Are any of you guys using the 2 Metco or other brand 100mm idler pulley's?
The larger idler pulley's give more wrap around the Radix pulley. That gives the belt a better bite, more pulley surface coverage, and will be less likely the belt will jump the pulley.
Just thought this might help those who haven't done this $90-100 mod.
Jim
Old Nov 20, 2006 | 08:17 PM
1SlowHoe's Avatar
not yet but, I have looked ino it. Since the tensioner is about $85 the bigger idler pulleys wouldn't be a bad idea. What I would really like is to find the 100mm idler pullied with a lip on it. The Metcos are smooth like the stock ones.
Old Nov 20, 2006 | 09:41 PM
LBSBLOWN's Avatar
Jim
Yes I have the 100mm pulleys and the belt still jumped, I think my trans shifts hard and that may be why the belt jumped but it never has done this before.
Old Nov 21, 2006 | 12:06 PM
Mort's Avatar
Cool
Very clean.
Old Nov 21, 2006 | 06:37 PM
Question
I like too!
Is it jumping off to the front of the pulley or back side?
Jim
Old Nov 22, 2006 | 09:21 AM
LBSBLOWN's Avatar
I like too!
Jim
It jumped off the front side, and it has only done that once.
I romped on it preety hard yesturday racing and beating a SVT mustang and
latter I waxed a 2006 vett.
The belt stayed on and no belt dust.
I think what happened to make the belt jump was the tensioner may have some interferance inside and may bind a little causing the belt to loose tension and jump off so I spray lubbed the inside of the tensioner and it seems to move with less binding.
