Radix 112HH Installed - Antifreeze smell when hot
Old Jan 14, 2009 | 11:03 AM
gdev_'s Avatar
Default Radix 112HH Installed - Antifreeze smell when hot
Ok, first of all, I had a shop install my kit, so I am not on top of what all I should check. I have put about 1000 miles on the truck since the Radix install, and when the truck is at full temp, I can smell antifreeze. It's not leaving spots in the driveway, and there are no obvious signs of anything leaking under the hood. The only thing I see is that if I remove the cap from the overflow tank for the intercooler, there is some antifreeze on the top of the tank, outside of the threads. Could I have a bad cap? Also, when I put the cap back on, should I be turning it until it clicks?
TIA!
Old Jan 14, 2009 | 12:28 PM
KySilverado's Avatar
Yes turn it until it clicks. With my recent trans change I spilled a bunch of antifreeze on the radiator core. I still get the smell too. Nothing leaking its just taking a long time to burn off the radiator I think.
Old Jan 14, 2009 | 01:11 PM
gdev_'s Avatar
Cool, I could see that happening easily. I'll just keep an eye on the fluid levels and make sure.
Thanks!
Old Jan 14, 2009 | 01:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
If the cap ends up being bad let me know, we will get you a new one right away.
Old Jan 14, 2009 | 02:19 PM
chevrolade's Avatar
i had a leak where the t connector is thats about it.hope u solve it
Old Jan 14, 2009 | 03:40 PM
gdev_'s Avatar
Thanks Brian, I'll let you know. With not seeing any fluids anywhere, I am leaning towards what KySilverado said....
Old Jan 14, 2009 | 09:40 PM
blue2003ls's Avatar
I second the t-connector. Mine ended up over the exhaust and it didn't leak out enough to be noticeable in the system but I caught it with a drip on the connector. Just gave it a quarter turn and it went away.
Old Jan 20, 2009 | 01:59 PM
Check the crossover tube. Mine leaks a minute amount there on the passenger side. I guess the o rings I put in it were a little off.
Old Jan 21, 2009 | 10:00 AM
OnyxSilveradoSS's Avatar
I have seen one IC core fail. small hole. That would be the last thing I would want to check.
superchomper2003
Aug 26, 2015 09:39 AM
black00chev
Jul 31, 2015 04:33 PM
BIGD4504
Jul 28, 2015 11:46 AM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
