Radix 112 pulley
Old Feb 18, 2012 | 08:25 PM
Blacksrt403's Avatar
Default Radix 112 pulley
What's the best radix pulley size that it's best considering iats/ timing ? Thanks in advance
Old Feb 18, 2012 | 11:27 PM
BlownG8Girl's Avatar
How much boost do you want to produce?
Is the bottom end stock?
What size is the engine?
Old Feb 19, 2012 | 12:03 AM
TX Tahoe Z71's Avatar
What's your setup? Mainly, displacement and exhaust setup. I'm running a 3.0" with catless LPP's and don't have any problems with IAT's, but also have the much larger Magnacharger CTS-V heat exchanger. I am at the end of the stock MAF's range too, so if I went with any more boost, I would have to go to a speed density tune.
Old Feb 19, 2012 | 09:22 AM
I have 05 gmc Sierra vho 6.0 with , pacesetters headers, 3 inch dual exhaust no cats, radix mp112 with 2.8 , 60 lb inj. 90mm ls7 tb,flt level 6 trans with 2800 stall. I was just wondering if the heat from 2.8 pulley hurts more than it helps. Iats are 30-35 higher than ambient I'm in south Florida. I'm looking into getting larger hex , what's your dimensions on yours and where did you get it? Trying to get setup as good as I can I'd like to throw a decent cam in. Thanks guys. With current mods I'm at 450 hp and 485 tq
Old Feb 19, 2012 | 09:46 AM
TIM Z's Avatar
11 sec. Truck Mod
Keep that pulley, put in a good blower cam and you'll really have a fun fast ride.
Meth might be your next mod/friend due to the hot/humid enviroment you live in.
A NNBS hex would help also with a mix of distilled water and waterwetter, this is a proven 10* drop in IAT's.
Old Feb 19, 2012 | 04:05 PM
Dimensions are twice as tall as the stock maggie truck h/e, same thickness and width. I think my IAT's cruising are about 20 over ambient, and 40 over after a 5-7 second WOT run (114 when it was 75 outside after a 7 second run).
Old Feb 19, 2012 | 05:06 PM
That looks real clean , you get it from Magnuson ?
Old Feb 19, 2012 | 06:05 PM
I did, but Frozen Boost has some good ones too (for a lot less). Didn't know that at the time. The one I have requires some trimming of the back side of the grill and a fabbed lower support bracket. Tootall and I made it out of aluminum square stock from Home Depot, it was pretty easy.
Old Feb 20, 2012 | 07:44 AM
Anyone use the Lep blower cam ? Can't decide on cam. Would like an all around cam I occasionally tow a 7000 lb boat so I would like down low grunt.
Old Feb 22, 2012 | 12:21 PM
Bump...
