Race gas and boost!!
Old Aug 6, 2011 | 11:59 PM
vicalma03's Avatar
Very true! Its speed density tuned. I think im just over excited with the boost!! I'll Just leave it alone for now and see what it will do. Thanks for the replys guys. Definetly dont want to ruin my motor anytime soon.
Old Aug 7, 2011 | 12:10 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Safe to say you're completely un-tuned above the 9 psi he dyno-tuned you at. I wouldn't push it.
If it were me, I'd have it tuned at the higher boost level, then DD on the low boost setting, and turn it up at the track, or when you "need to" on the street. Much safer, IMO.
As Cody said, timing is a critical part of the recipe for a boost tune. I'm guessing that if he set your fueling that rich (assumably to be safe), that he also has your timing at a "safe" level.
But I also believe that every engine "wants what it wants", and too much/too little fuel, or spark advance is not "good" for the engine. Is it possible that your AFR gauge is out of calibration?
Old Aug 7, 2011 | 01:21 AM
Spoolin's Avatar
GFYS and STFU
Mixing in race gas will help prevent detonation but it won't help you make more power unless your tuned for it.
Old Aug 7, 2011 | 03:00 AM
smokeshow's Avatar
Mod with training wheels
Adding high-octane fuel won't have an effect on the mixture of air and fuel per se, but it can give you some rich readings on your wideband. High octane fuel burns slower, so without enough timing, the mixture can exit the cylinder still burning. The biggest concern with that is EGTs...
Old Aug 7, 2011 | 06:54 AM
Gadgetized's Avatar
One thing to consider is if your 93 gas has 10% ethanol (if it was tuned for that). If it does, and your race gas doesn't, it will actually be richer compared to 93 as 10% ethanol likes a 14.3 compared to 14.7.
Old Aug 7, 2011 | 04:19 PM
tarinitup's Avatar
9 Second Truck Club
Allen is pretty safe with his tunes and doesnt just leave areas above 9psi untouched. I wouldnt worry about turning it up a few psi.
Old Aug 7, 2011 | 04:53 PM
Of course they aren't untouched, but they aren't "dialed in" either...
Gadgetized
Aug 21, 2020 03:14 PM
Razor
Dec 1, 2015 10:46 AM
slowlsx
Aug 13, 2015 08:28 PM
Gadgetized
Jul 18, 2015 02:15 PM
