Quik update
Old Dec 7, 2007 | 08:31 AM
beastmode's Avatar
Import Moderator
Default Quik update
this is what Quik has been up to just incase anyone has been wondering
"to details i have a PTE88. for some thats a precision 88mm turbo. .96ar. i have a Lunati 408 shortblock, ill be topping it off with a set of AFR 225 LBs, LS2 intake. my goals are 4 digits on the dyno, run mid 10s in full weight trim minus tires/wheels. i also have a 50mm Tial BOV on its way and will be picking up a 60 tial WG in near future. im using an Ebay 4" core, my intake tubing is
3" stainless then exiting and going to TB with 4". ill be running a 4" downpipe with exhaust and exiting out the side as my old exhaust once did. all tubing will be powdercoated and the hot side will be jet-hot'd.
some are concerning, my air compressor died so i couldnt do anymore cutting for the night, so some tubes need trimed up.
also to some of the gurus that done this if you see anything out of ordinary please comment on it
anyways now onto the pics"
Old Dec 7, 2007 | 08:39 AM
Tootall's Avatar
duct tape holds everything together !
Old Dec 7, 2007 | 08:40 AM
joshua022's Avatar
where did he get those valve/coil pack covers?
They look good
Old Dec 7, 2007 | 08:41 AM
beastmode's Avatar
Import Moderator
They look good
the fuel rail covers? they are off a vette i think... there always on ebay
Old Dec 7, 2007 | 09:44 AM
Tootall's Avatar
yep . . . and they're everywhere
Old Dec 7, 2007 | 10:01 AM
adam1803's Avatar
Wow! Thats very nice work
Old Dec 7, 2007 | 10:28 AM
wastedrubber's Avatar
Sick. What kind of boost will he be running with this set up? And how many cubes?
Old Dec 7, 2007 | 11:27 AM
beastmode's Avatar
Import Moderator
408. not sure bout the boost.
Old Dec 7, 2007 | 03:56 PM
Holty's Avatar
Notorious BIG
that truck is going to be rediculous once he gets the bugs worked out.
Old Dec 7, 2007 | 04:28 PM
BlackGMC's Avatar
Resident Retard
Why don't you enlarge the outlet on the IC to match the 4in pipe?
