Question for the turbo guys
Old Jul 25, 2012 | 11:42 AM
Byrdman11's Avatar
Default Question for the turbo guys
I'm going turbo on my 2011 silverado. Wanting to start with 8lb of boost be able to used a manual boost controller to adjust up to 10lb or so on meth. Question is my boost controller is a ball and spring style and how do you think i should run the hoses and what spring to run in gate. I'm was thinking I could run around a 8lb spring inthe gate and run a boost signal with manifold vac/boost to the boost controller then to the lower/down port of the gate and vent the top port. I have read up on this but wanting to see what you guys are running that works.
Old Jul 25, 2012 | 12:06 PM
nonnieselman's Avatar
I have always referenced the bottom port and put a regulator on the top port for extra boost..
Old Jul 25, 2012 | 07:56 PM
Byrdman11's Avatar
Do you tee off of the boost signal on the lower port and run hose to regulator then to the top port. You think my style boost controller would work this way? You use a small air regulator right?
Old Jul 28, 2012 | 04:21 AM
slowec's Avatar
Intake manifold referenced
TAPyvehc93
Jul 23, 2017 10:54 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
