Question on front mount
Old May 7, 2011 | 05:48 AM
droppedchev's Avatar
Default Question on front mount
I'm building a front mount I'm running a s400-75 question is there is not boost pressure port to run to the wastegate do I just drill and tap it where ever I can fit it on the compressor cover
Old May 7, 2011 | 05:51 AM
stock48's Avatar
9 Second Truck Club
I run mine off the intake.
Old May 7, 2011 | 08:52 AM
bud8fan's Avatar
off the passenger side of the intake toward the firewall there is a port there to use...
Old May 7, 2011 | 09:06 AM
I'm talking about from the turbo I don't need to run no line from the turbo to the wastegate then the Blowoff to the nipple on the side of the intake or just throw a tee in on that line and run it to the wastegate
Old May 7, 2011 | 09:53 AM
kbracing96's Avatar
x3 ^^^
Use the port on the intake with 1/4 hose, "T" it and run one to the waste gate, and one to the blow off valve.
Old May 7, 2011 | 11:11 PM
blue0453's Avatar
this is something like what I use. Just run a line from the intake to it, then you can run a line to everything else from the distrubution block.. http://www.jayracing.com/index.php?m...roducts_id=210
Old May 7, 2011 | 11:46 PM
bud8fan's Avatar
why not...better to get the true psi from the intake than from the turbo since your going thru tubing,intercooler,tubing and then the intake...get a boost/ vac block...installit on your firewall and boost/vac reference from it...alot easier and cleaner...
Old May 8, 2011 | 06:13 PM
joeyc125's Avatar
11 Second Truck Club
Correct, and the pressure read at the turbo outlet is usually a little different than what the engine sees at the intake due to the tubing, intercooler, and the velocity of the air blowing past that nipple at a 90 degree angle at the turbo. More accurate at the intake.
Old May 10, 2011 | 04:00 PM
anybody know where i can get the little y fittings to build my twin fuel pumps and how does the wires come up threw the bucket
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
USMCvet0311
Aug 1, 2015 07:45 AM
Deceptarado
Jul 8, 2015 05:24 PM
