Purchased Trick turbo kit. 09 4.8L Now for the help
#53
I have to thank Rick at Trick Performance for his help and quick replys to texts.
also I am in contact with fiveomotorsports as the injectors came with the wrong electrical plug, but they are being very helpfull, and trying to solve the problem.
If anyone wants Tuning in my area for GM gas or diesel motors I can hook you up with my tuner.
#56
didn't know if it was necissary or not. normally im all about
and half *** jobs, but this one was so easy it has turned out great!
#59
This is MarkGMCCrew here with my New Profile not sure what happend to the old one... But glad to be back
Also I have a question Im getting the P069e code with my flex fuel pump in my non flex fuel truck. Im not sure if the pump is causing this or what it is.
#60
I have looked high and low and cant seem to find any one with this issue, Im getting a flow test fail code from my FPCM, I believe it is because of the flex fuel pump in the non flex truck, it always has at least 10 psi higer than commanded. will this cause a failed test? at the same time im still getting lean bank 1 and 2 so its confusing... any ideas are welcome.
