Pulley size and boost levels
It does run strong. The torque off the line is sick. I'm pretty sure it's well into the 11's now at full weight. The problem is, they closed our track and I will have to drive for a couple hours to go make a run. My next step before I do that though is to install some ID injectors and clean up the tune. Shooting for 600rwhp.
Maybe I am. After the big headers, exhaust, smaller pulley and new tranny, this truck is a new beast. It feels like it has 25% more jam. That 3" exhaust system was really holding me back. I had 4 big guys in it today and did a 4wd launch. It was hot out but felt like my fastest run yet.
Can't wait to dyno it and then run a 1/4 mile.
I will slap on a 2.9 soon to see how much boost I make, but I wouldn't be surprised to only see 8# or so, in fact its what I would expect.
Yea I agree that its not something to worry about.
Sure there are better cams for your current build, but I certainly dont think its holding you back. At this stage in the game I would most likely not do the GT2-3... I think you could do a lot better.
I swapped to a 2.9" pulley on my 1900 and It netted me around 3 PSI more on my current set up from 5-5.5# to 8-8.5#.
I expected more... but I guess we'll see as I can spend more time with it. Hopefully the OD crank wills still put me around 11-12 or so. I also expect that uncorking the intake tube would help a lot, but a slightly larger exhaust might bring me back to where I started anyway.
Logged some nice runs with the 2.7" last night and it netted me just north of 10# in second gear. I think the OD crank will get me to 12.5 to 13. Perfect. I have a few more changes to make in adding a more free flowing exhaust and a 4" intake, but I think they may net each other out from a boost prospective.
TVS 1900 on a bone stock 09 5.3 single chamber flowmaster is all that is done to the exhaust system. K&N drop in filter to stock air box.
3.7"=5 psi
3.4"= 7.5 psi
3.0"= 12 psi
4.0 Whipple on 408 ls. This has a 8" crank pulley. Around 10:1 comp. 251/261 @.050" on a 114 lsa. 5" inlet. stock 243 heads. 1 3/4 full length headers and dual 3" exhaust.
5.0"= 9 psi
4.2"'= 15 psi
3.25"= 26 psi
3.7"=5 psi
3.4"= 7.5 psi
3.0"= 12 psi
5.0"= 9 psi
4.2"'= 15 psi
3.25"= 26 psi
Figured I'd give a little update here.
I tossed on the 8 rib belt system finally... OD crank (8.25") and the 2.7" snout gets me just north of 13# when loaded in second gear. When I first hit it I see around 11.5# or so.
I'm willing to bet as things cool down I will see in the range of 14 PSI.
