pulley removal
Old Oct 30, 2009 | 04:37 PM
crazyhorse's Avatar
Default pulley removal
like to change pulleys on my magna- charger,was informed to try a breaker bar and a rubber malet.righty tighty lefty loosey,anyway it is'nt working.it has'nt been on very long so rust ain't the problem,anybody got any ideas ? oh i forgot i was instructed not to use a air gun .
Old Oct 30, 2009 | 04:41 PM
thunder550's Avatar
High on diesel fumes
Are you trying to get the nut off or the pulley?
For the nut, use a strap wrench to hold the pulley in place and just take a socket wrench to the nut.
For the pulley, get a 3 jaw gear puller.
Old Oct 30, 2009 | 05:34 PM
norris_83's Avatar
thank god for the tvs
Old Oct 30, 2009 | 06:09 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What he said.....
Old Oct 30, 2009 | 06:10 PM
BlownChevy's Avatar
blownerator
25 Year Member
Tell whomever told you to use a breaker bar and a mallet to stop working on cars and join the circus. I love how he told you to not use an air gun, but told you to beat it with a mallet
You will need a strap wrench or belt wrench, a breaker bar and a buddy to help. The bolt is torqued to 45 ft pounds.
If you do not have a belt wrench, you can make one out of an old belt and some vice grips.
Old Oct 30, 2009 | 06:15 PM
Attn Brian, DO NOT READ THIS POST!!
I removed the nut with an impact gun. Unless you're doing something stupid, you won't have any trouble.
Old Oct 30, 2009 | 07:00 PM
old motorhead's Avatar
What's the problem with using an impact to REMOVE the nut? Just grab the pulley with a gloved hand and blip it off. That's the only way I've ever done it. Yes, use a gear puller to remove the pulley. Also, don't tell Brian that I normally use an impact to tighten the gear puller It's a little known fact that most impact wrenches have a slow speed low torque ability.
Old Oct 30, 2009 | 09:42 PM
BlownChevy's Avatar
blownerator
25 Year Member
I will note that when you guys call me with broken pins on the isolator and shaft Happens all the time, and its ONLY 750-850 to repair since it destroys the rotor.
If you have done it in the past then you have been lucky, those pins are designed to break if the blower ingests something....and the force you put through the blower shaft with an impact gun will destroy your blower...sooner or later.
Bottom line, dont cut corners and do it the right way with the right tools.
Old Oct 30, 2009 | 09:44 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
....PWND.
Old Oct 30, 2009 | 11:10 PM
Rick_Vor's Avatar
Nice! Now I'm glad I didn't throw away that old, stretched out Procharger belt...
Rick
