Pulley change, but no boost change!!!
Old May 3, 2010 | 09:47 PM
SincalT/A's Avatar
You need a bigger tb. for sure.
Old May 3, 2010 | 09:55 PM
02'Z71ONDUBZ''s Avatar
Originally Posted by acethedragon
are u still runnin the stock throttle body? if so, would consider the 90mm upgrade to let the blower breathe. a mp112 radix, like similar blowers has to suck air thru the tb which becomes the restriction. opening that up will help it build more boost. also remember the faster you spin the blower, the more heat it will build. that could be offsetting the added boost you thought you would get. hope this give you some ideas
I doubt the throttle body is the problem. There are lots of people making big power with a 78mm tb. I don't think he reached it's limitations with that pulley change. Nevertheless, a 90mm conversion is a good mod. Also, even though he is spinning the blower faster with the pulley change, it should still create more boost than prior. If heat becomes a factor, well that affects the amount of power the engine makes, rather than the amount of boost the blower is building. Someone correct me if I'm wrong. If heat does become an issue, I would consider a methanol injection system.
Old May 4, 2010 | 01:52 AM
Spoolin's Avatar
GFYS and STFU
Your right on both counts Tyler.
Also Stock48 is still sporting his stock 78 and he's in the mid 9's!
Old May 4, 2010 | 06:25 AM
blownss06's Avatar
I am making 1# more paid but that 1# doesn't come in till around 5000 rpms. I would think I would get full boost right away.
Old May 4, 2010 | 06:45 AM
scooter k's Avatar
I don't think you are going to see it build right away. Mine comes up fast but never starts to make max boost until up in the rpm range too.
Old May 4, 2010 | 07:27 AM
03sierraslt's Avatar
While this is true, his 78mm is a blow through where as the magnacharger is not. Big diff.
Old May 4, 2010 | 11:04 AM
BlownChevy's Avatar
blownerator
25 Year Member
someone knows what they are talkin about
Old May 4, 2010 | 09:21 PM
acethedragon's Avatar
tru blownchevy. something pressurized will always flow more than same thing under vacuum. thats the whole point in getting blown in the first place. lol.
Old May 4, 2010 | 09:53 PM
old motorhead's Avatar
Bigger TBody or better intake. Maybe as simple as cleaning your air filter. Either way, there's a restriction on the intake side.
Old May 9, 2010 | 10:29 AM
Any update on this?
