PT88 build, 6" intercooler!!
Old Jun 25, 2008 | 08:43 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Rick@Synergy
Rick, that intercooler is going to be very difficult to cool. The thicker the core, the harder the air is on it. Keep that in mind.
R
Hey Rick,
its a trade off,
yea the longer the tube the same type of issue. The mount area just does not have enough height to give a large enough core sizing so we went thicker/shorter tube length. This will help the cfm through the core while still yeilding a cool outlet temp. The thinner longer tube stuff you have to increase the inlet pressure to get the cfm through the core and your starting with a hotter air temp.
The thickness to tube length is what my intercooler guy spec'd out so far has not been wrong. knock of wood.
It should be an interest ride once done.
Old Jun 25, 2008 | 04:12 PM
8ALTNG's Avatar
Nice setup. But I do think the turbo is a little small. I would have gone with a S-91 or S-85. Maybe even a Turbonetics thumper
Old Jun 30, 2008 | 03:31 AM
14 Second Truck Club
I think it looks cool except the stock intake/tb. Need to put a vengence ported FAST 92/92 set-up and let that air in!
Old Jun 30, 2008 | 03:44 AM
stock48's Avatar
9 Second Truck Club
A PT88 will flow enough air to feed a 500CI big block to moderate boost levels. Should have no problem making good power, with quick spoolup on a 427.
Old Jun 30, 2008 | 04:50 AM
7845's Avatar
Banned
its going to be choked up on that 427. being only a t4 flange its going to run into backpressure as rpms rise.
Old Jun 30, 2008 | 11:07 AM
zippy's Avatar
I agree that I think the turbo is a little small, but as long as he is just looking for reasonable (8-10psi) boost levels it should be just fine. At 8psi that 7.0L should be quite impressive.
Old Jul 1, 2008 | 10:44 AM
DrTurbo's Avatar
LS1TECH Sponsor
Please place a PT88 on a 500ci engine. Count the bolts from the heads that fly out of the block when it lifts the heads off in .1 seconds.
PT88 has no business on anything larger then a 370-380ci engine. Backpressure will climb through the roof quickly. A GT47-88 would be better suited with a large A/R of if you need something compact then a S88 which has a larger turbine wheel even then the two mentioned. But either way a 427 needs a T6 unit.....T4 is asking for trouble.
Nice looking kit though guys......good stuff either way.
Old Jul 1, 2008 | 02:31 PM
stock48's Avatar
9 Second Truck Club
Some guy's have ran them on 8.1L's. Im only talking about reving the engine to 4500~5K. I only shift my 6.0L T76 @5200RPM. The larger engine would have more of a diesel like power power curve. I watched a video where Parish made 1K RWHP @22~26PSI of boost. That was on a 408CI. I don't see how you couldn't run a T88 up to 12~15psi on a 427. I do agree that the back psi will be high if you rev the engine past 5500~6000RPM. I just don't see it necessary for every Turbo engine to be a rev king.
Old Jul 1, 2008 | 02:45 PM
DrTurbo's Avatar
LS1TECH Sponsor
Agree, but a GT47 or S88 would spool the same if not sooner and make more power per PSI and you can still rev the motor to what RPM you want. Just something to think about.
Old Jan 4, 2009 | 10:27 AM
OnyxSilveradoSS's Avatar
so is a PT88 any good on a 6.0L
