procharger truck setups.
I'm doing a 6.0 swap in to my mustang and am trying to check all on my options. i have a D1SC that is standard rotation so i would like to use it on my build. do the truck bracket/tensioner use standard or reverse rotation head units? also do they use there own belts or are they ran off of the serp. belt?
thanks,
Dan.
thanks,
Dan.
he truck bracket spins them in the right hand direction.. They use the serp belt, unless you go for the cog set up, offered by procharger.. Or depending how much time you have you could make your own cog set up..
You should be able to get away with 11-12 psi with out serious belt slip on the D1. Other wise you will want go with a 6 rib set up which is $$$ or then to a cog set up, which is $$$..
6 rib? isn't stock 6?. i think I'm just going to try and find a different bracket setup. I'm thinking the gto on. thanks again guys, i just noticed your signature thats the best statement Ive heard for owning a procharger
Oops my screw up, I mean 8 rib
Yah this site used to be very partial to them, still kinda is, but after getting my belt issues fixed, I have nothing bad to say about them.. Truck screams,,,
This was the sig, but we are going for the old skool, goofy look for a bit
