the procharger thread
Old Apr 23, 2012 | 08:16 PM
phasemaster1's Avatar
D1sc
5.3
216/220 cam
long tubes catless single 3" dump
4l80e stock verter 3.73 gears
4.25" pulley
8lbs shifting at 5700
Old Apr 23, 2012 | 10:26 PM
blown02408's Avatar
02 w/ lowest mileage 2800
408 with lunati rotating assembly, 8.5:1, Stage III 6.0 heads, Comp 234/244 .576/.596 114+4
First Setup: P1SC 3.4 pulley 11psi 60lb/hr injectors 520rwhp @5500rpm 520rwtq @4400 no intercooler meth only
Secong Setup: D1SC 3.4 pulley 17psi 80lb/hr injectors 700rwhp @6000 w/ belt slip no intercooler meth only
New setup still in the works: F1C 8.25 lower 4.75 upper pulley front mount intercooler dedicated 12 rib drive
Old May 12, 2012 | 01:30 PM
AndysC3's Avatar
will a Procharger form a 03-06 work on a 01?
Old May 12, 2012 | 01:47 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes..
Old May 12, 2012 | 01:49 PM
AndysC3's Avatar
hmmm, Thanks
Old May 12, 2012 | 02:01 PM
ak2007r6's Avatar
I don't think the Procharger unit it self is different it's just the mounting bracket.
IE if you find a D1 for a Ford all you need to get is the bracket for your vehicle..
not positive but that was my understanding, someone correct me if I am way off in left field.
Old May 12, 2012 | 02:04 PM
AndysC3's Avatar
Im looking at a procharger kit thats on a 03 yukon
Old May 12, 2012 | 02:19 PM
Baltimore Whore
This is tru, unless it is a opp rotation unit. Also always remember that where ever the tag is on the unit, it always has to be facing up at you. That is where the oil slinger is located, as it has 3 positions, can be reclocked.
Old May 13, 2012 | 01:40 AM
GMC3's Avatar
Sierra C3
6.0L P-1 @ 11psi
Fully built 4L65E w/ yank 3200
stock cam and heads
12.53 @ 105 mph
shifting @ 6000
Old May 13, 2012 | 04:23 AM
idahoblkss's Avatar
on your second set up were those numbers on a 408?
