Procharger Shelled Out
Old Apr 13, 2006 | 02:22 AM
2lugnuts's Avatar
Default Procharger Shelled Out
Procharger Shelled Out My Procharger burnt out tonight, its making a hard bearing and knocking noise=dead.
Im worried that fragments went into my intake what is the best way to check for motor damage?
Old Apr 13, 2006 | 02:42 AM
F8L Z71's Avatar
Compression check and leakdown?
Thats how I fried my first 5.3L. Had gravel fall into the cylinders and didnt know it. Within 10min of start up it started spewing smoke out the tailpipe
Old Apr 13, 2006 | 02:52 AM
Wilde Racing's Avatar
How do I change this text
How
Id pull the intake, (going to need to clean it anyway) and check for pieces in the runners before turning the engine over. Don't want to chance any more getting in the cylinders. If they are all clean, you would just need to clean the intale manifold really good. I'd still to a leak down test.
How long did you run it after the bearing failed? any missfires?
BTW, It's pretty sad the number of poeple who can't sleep at night.
Old Apr 13, 2006 | 02:57 AM
F8L Z71's Avatar
Originally Posted by Wilde Racing
How
Back when I had the engine fire and the only way I could put it out was with dirt/gravel. When I yanked the Vortech cover off the manifold it made a hole in the manifold and I guess rocks made their way into the heads? You could see indentions in a couple pistons on one side. It was ugly lol.
Old Apr 13, 2006 | 08:50 AM
Bad_Apple's Avatar
dang man thats sucksss....
Old Apr 13, 2006 | 10:29 AM
2lugnuts's Avatar
"How long did you run it after the bearing failed? any missfires?"
Well I had to pull out the way so my truck was still running for a bit, from what I can tell it did'nt miss fire I think the Prochrager cooked internally.
It sounds pretty bad like a nails on a chalk board.
What the hell is a leak down test btw?
Old Apr 13, 2006 | 10:40 AM
It sounds like you just lost a bearing, pull the charger and check for metal.
A leak down used two gauges on a manifold, a regulator, and shop air. With both valves closed you measure the amount of air going past the rings. Air will get throw, but how much tells you what the condition of the ring/cylinder walls etc. are in. It's like a compression test but the engine is not spinning.
Old Apr 13, 2006 | 02:12 PM
2lugnuts's Avatar
Wilde, Thats helpful does that all come together as a kit to buy? or is it worth bringing to a shop that has one? The bearings sound toast that's the first thing that came out of mind head when I heard it.
I took the Procharger out the teeth on the impeller broke on the edge and all edges of it rubbed against the charger casing.
Old Apr 13, 2006 | 02:40 PM
hmm, I'd pull all the tubing and intake manifold and clean it, but It doesn't look like there are going to be any large chuncks. Just fine metal, depending on how much you find would determine if the engine comes apart imo.
I'd remove the hump hose at the thuottle body and look very closelly for any aluminum. if there is none traped between the throttle body and plastic tube, chances are your engine is fine.
I just looked at your sig pic, Do you have a cooler after the charger?
Leak down testers are pretty easy to use, and some what cheap. just make sure if you buy one it has the right threads for the spark plug hole. most have three different hoses included. Leak down testers also help changing valve spring with the heads on.
Old Apr 13, 2006 | 02:54 PM
2lugnuts's Avatar
You have been nailing everything wrongwith it I believe you know your $hit...
Yes it has an intercooler at the bottom, other thing to is a few days before it went out there was an oily residue on the outside of the Charger.
I checked the oil but it looked fine I don't know if it was on the way out. I only had the Charger for about 2 months and its toast maybe a "lemon".
The only thing that worries me is a fine silver dust all over the inside of the charger and tubing. You can see it here...
