Procharger Serpentine belt
Old Feb 15, 2013 | 10:21 PM
  #51
03sierraslt's Avatar
Sounds like you have regulator issues.
Also Boost Juice is not even classified as a flame able due to only being 49% Meth.
Old Feb 15, 2013 | 10:23 PM
  #52
AndysC3's Avatar
and yes, I have ran without the filter and it made no difference
Old Feb 15, 2013 | 10:33 PM
  #53
SCREAMINXL's Avatar
Maybe a test run with the bypass removed/capped off? Definitely get more fuel in that thing! Should be able to band-aid it with a larger nozzle or high concentration of methanol.
Old Feb 15, 2013 | 10:36 PM
  #54
AndysC3's Avatar
I may throw 2 gal or so of 100 oct. Im down to 1/4 tank now.
Old Feb 15, 2013 | 10:45 PM
  #55
SCREAMINXL's Avatar
I was referring to it running lean not your fuel tank! Removing the filter netted no boost gain? Seems like everyone including me gain a couple pounds of boost running no filter. Makes me think your bypass is having trouble holding anything above 10 psi.
Old Feb 15, 2013 | 10:52 PM
  #56
AndysC3's Avatar
I may try to cap it but not sure how
Old Feb 15, 2013 | 10:56 PM
  #57
SCREAMINXL's Avatar
Flexible Coupling - 1.5" Rubber Test Cap or Cleanout
Hardware store, Lowes, Home Depot.
Old Feb 15, 2013 | 10:59 PM
  #58
AndysC3's Avatar
Just thought about it, that could end badly when I let out at about 9-10 psi and it has no where to go lol
Old Feb 15, 2013 | 11:02 PM
  #59
SCREAMINXL's Avatar
I have tried it before. Just ease out of the throttle, don't chop it closed and you wont have a compressor surge. Testing only!!!!
Old Feb 15, 2013 | 11:06 PM
  #60
SCREAMINXL's Avatar
I agree! I liked straight methanol the best! If I remember correctly you had good results with 80+% Methanol.
