Procharger HELP
Old Jul 19, 2011 | 12:52 AM
smokeshow's Avatar
Mod with training wheels
Stock pump will take you far... No need to replace it unless you are chasing over 600rwhp...
Old Jul 19, 2011 | 01:05 AM
08cheyennesc's Avatar
Spend the $$$ on a 8 rib set up
Old Jul 19, 2011 | 03:18 PM
idahoblkss's Avatar
Originally Posted by fcompean
Aright guys..need help...
I have an 08 silverado 5.3 that is getting procharged next week..
I was told by a tuner that I'm going to need a different map sensor and boost a pump..
What do u guys think? I have an 8lb and 10lb pulley..
I would really like to go with the 10 lb pulley..please help
you might be able to get away with a stock fuel pump on a 5.3 but i would put the bigger pump and injectors in that you have and be done with it to have room to grow and would put the pump in the bucket to keep the noise down if you got the how to do it. you would be fine with the stock sensor but your tuner might have been wanting to put you on a speed density tune and might want you to get a 2 bar map sensor ?? might want to ask him his reason for you to get the sensor !?!?! put the 10lb pulley on and sell the 4.0 pulley.
Old Jul 19, 2011 | 03:34 PM
Mangled03gmc's Avatar
Baltimore Whore
If he is only going to 10 psi the 8 rib is a little over kill imo.. He should not see any slip with 10 psi on a 5.3
Old Jul 20, 2011 | 10:09 PM
fcompean's Avatar
has anybody here changed the stock pump to a Walbro 255 on a NNBS??
any links?
Old Jul 20, 2011 | 10:13 PM
I'm almost 100% sure he won't stay at 10# for long,that's what I'm at now and going for more.
Old Jul 20, 2011 | 10:18 PM
jg53's Avatar
This is completely irrelevant, but I like that avatar, Chalino Sanchez!
Old Jul 20, 2011 | 10:41 PM
black04's Avatar
You cant run an inline pump on a returnless fuel setup.
Old Jul 20, 2011 | 10:54 PM
Baltimore Whore
^^^^^ Good call, I didn't even see he was a 08 truck
Old Jul 20, 2011 | 10:57 PM
fcompean's Avatar
so its either an in tank pump or a boost a pump?
any problems with boost a pumps?
