Procharger guys I need ansewers, I know you havem
Old Aug 20, 2008 | 09:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Like what was said above, free flowing exhaust (head work etc) will lower boost #'s by allowing the cylinders to fill more efficiently leaving less pressure in the intake manifold (where boost is measured). Belt slip isn't going to help either
Old Aug 20, 2008 | 10:16 PM
Mangled03gmc's Avatar
Baltimore Whore
I hope thats the case not that it is running bad, just so that I know, ya know LOL.. It all is prob playing a part here..
John
Old Aug 21, 2008 | 12:35 PM
WJ MARK's Avatar
I bet its belts slip. Try some belt dressing just to see if it goes higher. What kind of belt are you running?
Old Aug 21, 2008 | 02:43 PM
Baltimore Whore
Goodyear gatorback...
John
Old Aug 21, 2008 | 05:09 PM
TurboJohn6's Avatar
John
They have worked the best for me. The gatorbacks seem to have good grip.
Old Aug 21, 2008 | 05:46 PM
NegraRCSB2X4auto's Avatar
You know I was having a similar problem before I had my boost gauge in. I notices that when I would rev it up and decel quickly the bypass wouldn't release any air. So I took it off and opened it. It had a thin plastic inside that looked like it had been sucked in and wasn't sealing right. It also looked like it was starting to so wear as if oil had got in and was deteriating the plastic. Well I don't know anything about these things so I just set the plastic back on where it sealed like it was suppose to asembled it back together. Took it for a spin and I hear the "**** ****" sound once again. I've also read that sometimes if you turn them the opposite way and the bypass worked better. So If i were you I would first try and turn it 180deg and see if you see any improvements. If not take it apart and check that thin plastic that's inside make sure there are no holes and that it's setting in there right.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
