procharger gurus .. need info please...
Old Jan 12, 2010 | 02:36 AM
Blown06's Avatar
8 Second Truck Club
Originally Posted by Rick_Vor
When I ran 4" exhaust wrap covered aluminum tubing from the head unit to the OEM fitler location, I saw about a 10 degree drop in AIT's but it cost me about 1/2 lbs of boost (dropped from 10 to 9.5).
Sounds about right. You will have to run a 4.25" to stay down around 10lbs. The nice part is you won't have any issues with belt slip.
Rick
I agree with this post 100%
Old Jan 12, 2010 | 11:53 AM
idahoblkss's Avatar
yeah currently have stock cam and i em not running meth. thinking about doing the e85 conversion but not sure cause there are only 2 stations in town here that sell it and they are on the other side of town.
Old Jan 12, 2010 | 11:55 AM
idahoblkss's Avatar
Rick
so would you guys take the 10 degrees over the 1/2 pound of boost?
Old Jan 12, 2010 | 01:05 PM
sharpshooter's Avatar
I think you should look into meth or larger injectors because with the cam you might have a problem with running lean.To run mine I needed 72 #er's and an 044 pump[255 intank couldn't keep up] but this was without meth.I know you are going for less boost but it will be tight with your injectors.
Old Jan 12, 2010 | 01:27 PM
Mangled03gmc's Avatar
Baltimore Whore
Damn Russ you need 72's to keep up?? I am only at 75-78% IDC with my 60's You must be making *** breaking powa
Old Jan 12, 2010 | 01:43 PM
John, I'm running 60's like you but they are actually 72#er's at our fuel pressure.His are 44#er's at 58 psi.
Old Jan 12, 2010 | 03:30 PM
idahoblkss's Avatar
you are correct when i do my cam swap im getting 60#ers for sure. what injectors will i need and are they plugg and play or will i need to splice. i rather not have to splice if possible.
Old Jan 12, 2010 | 03:37 PM
sureshot's Avatar
SRT10KLLR sells 60# Multech injectors that are plug and play. You can go with other injectors, they will be a little cheaper but you will have to splice the wiring.
Old Jan 12, 2010 | 03:47 PM
there are 73 # plug and plays and can't remember who sells them, Justin @ Blackbear knows
thanks Sureshot and they are 73 at our psi
Old Jan 12, 2010 | 04:26 PM
idahoblkss's Avatar
how do you guys feel about the cam im getting?
