procharger gauge setup
Old Sep 5, 2011 | 09:51 PM
Atomic's Avatar
I have a gauge for that
boost, afr, fuel pressure, oil temp...
Old Sep 5, 2011 | 10:31 PM
02'Z71ONDUBZ''s Avatar
Will a turbo heat the oil up enough to cause issues? Ive never thought about this, if anything I would have thought an EGT would be the next choice for a turbo setup.
Old Sep 6, 2011 | 08:48 AM
Atomic's Avatar
That is what im wondering, especially under high boost conditions. EGT isnt as important on gas engines as it is on diesels.
Old Sep 6, 2011 | 06:57 PM
TimDave217's Avatar
the reason i was wondering about the oil press. gauge is because of the oil drain on the turbo, I have some knowledge of turbo's but never have owned anything turbo'd thats why i was wondering if the oil drain had enough press. going through it to cause problems.
Old Sep 6, 2011 | 07:36 PM
Atomic's Avatar
oil drain should have basically no pressure, thats why guys use huge drain lines. I use a -4 feed and a -10 drain...
Old Sep 6, 2011 | 07:57 PM
smokeshow's Avatar
Mod with training wheels
Only causes issues if you don't change the oil regularly enough, or if the oil lingers in the turbo due to a poorly set up return line. Either way, the heat from the turbo is going to reduce the life of your oil. I believe foose04 posted up a pretty good article about that a few weeks back.
Old Sep 7, 2011 | 07:18 PM
TimDave217's Avatar
yea i've seen the article, and thanks for clearing that up i assumed it wouldn't but then thought about it and wondered if there was enough pressure going through the oil drain to do some damage. its cleared up now
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
D1SCSS
Jan 25, 2016 10:14 PM
thunder550
Oct 8, 2015 04:53 PM
