ProCharger fuel pump questions...
Old Jun 30, 2006 | 12:56 PM
Superado's Avatar
11 Second Truck Club
Default ProCharger fuel pump questions...
ProCharger guys,
Do you hear your frame mounted ATI supplied fuel pump running when key is switched on but engine not started?
Do you hear it continue running after ignition is cut off, but before opening door?
Have you replaced it with either another of same or a different pump all together?
Old Jun 30, 2006 | 02:17 PM
Bad_Apple's Avatar
I never here my supplied pump thats frame mounted. It has gave me no problems so far.... "KNOCK ON WOOD"
Old Jun 30, 2006 | 02:22 PM
Superado's Avatar
I heard mine from installation right up until it went out on me last year. I had probably 70k miles on it at that point. I had it replaced with another from ATI and I believe that this shop wired it differently for me so it would not continue running. I was told by ATI that even if it was wired so that it continued running as an accessory, that with the return fuel system and closed injectors, it would not be a problem.
Old Jun 30, 2006 | 03:41 PM
Blown330's Avatar
Never hear mine unless I put my ear next to it while running. Only hear it when it kicks on when the key is turned to "on" before starting. Have mine bolted to the frame channel with rubber grommets to isolate it.
GXPJAY
Feb 13, 2022 08:15 AM
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
