procharger filter mod
Old Jun 22, 2012 | 11:53 AM
idahoblkss's Avatar
Originally Posted by Pc2000trk
I don't use anything on mine either , on the dyno to the tires no filter gained 40 something hp - I use to have a screen but it was restricting to ( not much though ) if your worried about paper and plastic that blower will suck it straight through that - that thing will stop lumber and branches lol - but never hurts to have
i was thinking it was around 50hp gain the way it pulls with it off . when you dynoed it with the filter off did you see the boost kick in sooner and did you see a gain in boost?
Old Jun 22, 2012 | 11:54 AM
Originally Posted by idahoblkss
i know some of you know if you remove your filter from your prcharger you will gain 2-3 psi in most cases.i cant bare the fact of running no filter thou and so i made this from my scrap pile of parts. i wont be running it on a daily basis but when i go out to the races and what not "cough cough" . are any of you guys running anything else out of the norm ?
this is what i did...
How much PSI are you running on that? That looks like a good idea for the track...
Old Jun 22, 2012 | 11:59 AM
idahoblkss's Avatar
according to my logs in hpt its hitting 15.9 psi with the filter, i havent logged it with out the filter yet but my gauge reads 2 psi more but its a digi gauge so its can be off sometimes. last time i went out to log with the filter off i spun my water pump pulley off lol. i will be going out this weekend to log it and ill report back.
Old Jun 22, 2012 | 12:07 PM
I'm in for the results! Looking to see if it will hold when I go to 20+ after procharger upgrade....
Old Jun 22, 2012 | 12:12 PM
Pc2000trk's Avatar
Man honestly I don't know about the boost & I have a huge convertor so I didnt really notice coming on quicker - mines pretty violent on the dyno , prochargers spool retarded fast , it seemed about the same
Old Jun 22, 2012 | 12:28 PM
idahoblkss's Avatar
how big is your converter ? how much psi are you hitting and what did you put down on the dyno ?
Old Jun 22, 2012 | 12:37 PM
ak2007r6's Avatar
Some of you guys are running no filter on the streets?? I guess I am to paranoid to try that.
The track is controlled and I know there won't be random dirt and other crap that I could suck up
Old Jun 23, 2012 | 08:15 AM
blown02408's Avatar
02 w/ lowest mileage 2800
Here's one I made up from a Spectre 6" to 4" air filter adapter and 1/4 grid stainless steel screen.
Old Jun 23, 2012 | 11:44 AM
idahoblkss's Avatar
that looks nice but the holes look big. did you notice change in boost with it?
Old Jun 23, 2012 | 04:49 PM
blown02408's Avatar
The mesh has 16 holes per inch so its small enough to keep nuts and bolts, wiring, or small pets out lol, but not so tight that it restricts flow too badly. Also its rigid enough that there is no possibility that it will get sucked in. 2 to 3 psi more on a maxed D1 when swapped from a 9" cone filter.
