Procharger D1SC installed
Old Aug 19, 2007 | 07:19 PM
sharpshooter's Avatar
Default Procharger D1SC installed
I installed my D1SC last week and got my pcm back yesterday from Westers.This thing is like a whole new truck. I wanted to know what rpm's you guys are shifting at[automatic trannys]with your superchargers or turbos?My truck has an all stock 5.3 and a 4L60E with a transgo and vette servo.
Old Aug 19, 2007 | 07:35 PM
nightrunner's Avatar
Mr. Obvious
im still on all motor but i shift out at about 5900-6000(superchips).
how was the gain on it of NA vs. SC? been going back and forth between the radix and procharger
what kinda boost ya runnin right now?
Old Aug 19, 2007 | 08:02 PM
I'm running 8 psi[max.]and it is night and day different.I use to run a 100hp dry shot and it has a lot more power than that.
Old Aug 19, 2007 | 08:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt run it any higher then 6K or you will risk floating the valves with boost.
Old Aug 19, 2007 | 08:27 PM
11 Second Truck Club
i heard the procharger is only good up too 6500 shifts or maybe shift around 6 so it can go up to 6500
Old Aug 19, 2007 | 08:34 PM
WJ MARK's Avatar
You need like a 3000 stall. After I put one with the procharger it was a totaly different animal. You'll make about 4 psi of boost right out of the hole!
Old Aug 19, 2007 | 08:47 PM
i also wanted to know if that what they told me about shifting at 6500 or 6 to shift at 65k was right about the procharger i am going with a 32kpi stall and a blower cam from tr..
Old Aug 20, 2007 | 07:34 AM
Bad_Apple's Avatar
You be better off shifting around 6000-6200 was high as I could go without valve float. Put some springs, cam, 3000-3200 stall and you will have one mean set-up. Probably be around 500 h.p.
Old Aug 20, 2007 | 04:26 PM
Blown06's Avatar
8 Second Truck Club
I shift my procharged set up at 7000 rpm.
D1SCSS
Jan 25, 2016 10:14 PM
blownss27
Aug 14, 2015 03:31 PM
fcompean
Jul 15, 2015 09:55 PM
