Procharger bracket with car intake??
Old Aug 20, 2011 | 10:52 PM
KDavis04ss's Avatar
Default Procharger bracket with car intake??
Anyone know if a procharger bracket, either one, Will still work with a setup like this?
Old Aug 21, 2011 | 10:37 AM
blown02408's Avatar
02 w/ lowest mileage 2800
yes, I ran a very similar setup. You will need to remove one of the bracket spacers and replace it with an idler like in the picture above. I replaced the lower left spacer with an idler and ran the belt differently than above, but if you can make that belt routing work it would be better.
Old Aug 21, 2011 | 05:51 PM
Bad_Apple's Avatar
Yes it will work I run a fast 90 on my truck.
Old Aug 21, 2011 | 07:04 PM
KDavis04ss's Avatar
thanks fellas, Apple do you run the same bracket as blown02408? Im not sure if there is a mounting difference in the two but I wanted to get the polished newer style. But now that I know the older bracket will work I may just go with it.
blownss27
Nov 21, 2016 03:32 PM
D1SCSS
Jan 25, 2016 10:14 PM
HectorM52
Aug 18, 2015 12:40 PM
