procharged trucks
just wanted to know if any of you guys that have a procharger in your truck pinned the crank or changed pulley? Also if you have videos of your procharged truck driving in the street or at the track please post them up... Thanks..
You drill a passage way where the crankshaft and and crank pulley meet, then install a pin in there to prevent the crank pulley from spinning on the crankshaft.
The blower at high boost will create a lot of force on the crankshaft pulley and it will slip under high load, reducing boost.
Crank slippage= BAD , and bad for boost.
No crank slippage= MORE BOOST !
