Procharged Escalade - how much 0-60 gain from higher stall converter?
Old Apr 27, 2008 | 11:32 PM
Blowndenalixl's Avatar
Default Procharged Escalade - how much 0-60 gain from higher stall converter?
I have seen others on this forum state that putting in a higher stall on a Procharged Escalade/Yukon/Tahoe/Truck will really improve performance. So far I would have to say that my Procharged Escalade is no match for my Radixed Denali XL.
So before I spend the dough on a new stall converter, will it be worth at least 1 second 0-60? More? Less?
Other info on the Sclade. Snow Meth Kit and Tune by Allen at Nelson motorsports. Ceramic headers, and Magnaflow exhaust. Only making 5lbs up here in high altitude Alberta.
I don't want to spend the money if it won't be of assistance. I should have just had Allen put on the Trick turbo when he was doing his other work for me. Did not have the $$ or guts to sneak past wife at that time though
Thanks All.
D
Old Apr 27, 2008 | 11:35 PM
TouchOfEvil04's Avatar
A nice size stall will be a huge improvment overall. The biggest problem once you get it would be maintaining traction on the street though.
I did a yank 3200 in my truck and it did wonders...so much infact i can't use first gear at all past half peddle or it just spins.
Old Apr 27, 2008 | 11:40 PM
Wow - even in full time AWD? That would be cool - roasting all 4 tires at once!
Old Apr 28, 2008 | 12:00 AM
Well i'm 2wd so i'm sure you would mor traction than I but i woud not doubt it if you get some good spin from it.
Old Apr 28, 2008 | 12:07 AM
WJ MARK's Avatar
no with awd it won't have traction problems. When I added a stall to my truck with the procharger it was a night and day difference. IMO every procharger should have a stall to go with it. A bigger tranny cooler is recommended also. If you tow with it I wouldn't go much higher than 2500. a 3000 stall will make you very happy!
Probably the best mod for the money especially with a procharger.
Old Apr 28, 2008 | 12:26 AM
MFIC's Avatar
I would go with a Precision vig 9.5 3400 stall. A friend with a TBSS and I with SSS have that converter with our FLt level 5 4l65e and we are both awd. I spun the tires from a dig on my stock bottom end at 10psi. The TBSS is NA and runs high 12's with bolt-on's. He spins the front a little at sea level and not so much up here at 5000'. I was disappointed with the procharger without the stall from a dig or 20-30 roll-on's. It will wake that thing up and I consider it to be very very streetable. The TBSS had a 10.5" 2800 stall before this one and it was way too tight.
Old Apr 28, 2008 | 11:04 AM
Well I am half way there as I just picked up a bigger tranny cooler from a friend who was selling his SS and never got around to putting it on.
Looks like a stall is a must.....
Old Apr 28, 2008 | 10:26 PM
Blown06's Avatar
8 Second Truck Club
I picked up over a second in the 1/4 going from a 10.5" 2400 stall Vig to a 9.5" 3400 stall Vig. Prochargers love stall.
Old May 4, 2008 | 09:58 AM
05chevy's Avatar
so i jus built 404 stroker for boost . i have a d-1 procharger goin on it also . my question is that i have a tci 3000 stall with FLT 4l60e will this stall be good enough or should i spend tha money on a vigilante. im goin to put 12-14 psi on it . n also would it be good to run meth ?
Old May 4, 2008 | 11:11 AM
WJ MARK's Avatar
i think that would be plenty of stal for you.
