Problem with missing/bogging above 6 psi
Old Mar 19, 2007 | 09:21 PM
  #21
Originally Posted by Jamesbond2509
If you are not throwing any codes, your plugs and wires are OK, you got sufficient fuel pressure, injectors and AFR are OK, - could this be a transmission problem. I had problem similar after screwing with shift points on the tranny. It felt like a miss but was actually the shift point set incorrectly.
good call. mine was just having similar problems. we adjusted some tranny settings and it seemed to go away.
Old Mar 19, 2007 | 11:21 PM
  #22
thunder550's Avatar
High on diesel fumes
I guess I should log all the trans PID's and see what they say.
Old Mar 22, 2007 | 11:32 PM
  #23
Yes & make sure that the up shift points and down shift points are set apart enought so that it is not "hunting" for the gear. I changed all my plugs and wires just to find that it was the tranny.
Good Luck
Old Mar 23, 2007 | 10:36 AM
  #24
thunder550's Avatar
Kyle and I made new plug wires and it seems to have gone away, I think that was it Simple fix.
Old Mar 23, 2007 | 12:34 PM
  #25
thunderwagen's Avatar
awesome glad to hear it is fixed. Now just keep her from catching on fire again!
Old Mar 23, 2007 | 12:48 PM
  #26
TurboGibbs's Avatar
So you had to burn all your wires up to find it....literally
Old Mar 23, 2007 | 01:07 PM
  #27
thunder550's Avatar
Yeah, I'm trying to quit.....
Yeah...we made some plug wires with 90* boots on the end. Plenty of clearance now. Also have heat wrap and fiberglass heat sleeves on them.
Old Mar 23, 2007 | 02:17 PM
  #28
64CAMINO's Avatar
SWEET! time to crank the boost up now then right?
Old Mar 23, 2007 | 03:00 PM
  #29
thunder550's Avatar
Damn right! I'm running about 8psi now. I want to start adding some timing at the track and tune it for the meth, then start adding more boost
Old Mar 23, 2007 | 03:29 PM
  #30
danv's Avatar
Glad to see it was something simple, I've been watching the post to see how it turned out, very cool.
d
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
hackrst
Sep 2, 2015 05:27 PM
