Problem with missing/bogging above 6 psi
#21
Originally Posted by Jamesbond2509
If you are not throwing any codes, your plugs and wires are OK, you got sufficient fuel pressure, injectors and AFR are OK, - could this be a transmission problem. I had problem similar after screwing with shift points on the tranny. It felt like a miss but was actually the shift point set incorrectly.
#23
Originally Posted by thunder550
I guess I should log all the trans PID's and see what they say.
Yes & make sure that the up shift points and down shift points are set apart enought so that it is not "hunting" for the gear. I changed all my plugs and wires just to find that it was the tranny.
Good Luck
#27
High on diesel fumes
Originally Posted by thunderwagen
awesome glad to hear it is fixed. Now just keep her from catching on fire again!
Originally Posted by TurboGibbs
So you had to burn all your wires up to find it....literally
#29
Originally Posted by 64CAMINO
SWEET! time to crank the boost up now then right?
