Power Nation - Truck Tech Project White Lightning
Old Jan 31, 2016 | 11:14 AM
YAMAHAGUY's Avatar
Default Power Nation - Truck Tech Project White Lightning
I usually watch all the episodes of Power Nation(formerly Powerblock TV) even though some things are pretty cheesy, but they do a decent job of anything auto with a good amount of DIY. Granted there is usually a lot of the details left out and their welding technical info is lacking, but I'm biased being a welder myself.
Anyways, Truck Tech has just finished up Night Train(LB7/Alison swap) and starred project "White Lightning" which is a 2010 2wd ECSB with a 5.3 with 150k on it.
1st mod was a DOD delete and stage 2 VVT cam and LS7 lifters.
I noticed they said you need a "special" harmonic balancer puller. I haven't heard that before, but would be good to know since I will be doing a future cam swap also on a older 5.3.
They mentioned future mod was adding forced induction being boost, but didn't mention what form of boost.
Old Jan 31, 2016 | 01:07 PM
gravedigger472's Avatar
Hi, LT here. Glad you liked today's episode.
You can pull the LS dampeners with a conventional 3 jaw puller around the inside of the hub, it's just much easier with one made for a LS. There are three small tabs around the inside of the crank hub. Btw.. It's actually called project white noize.
Watch next week to see the suspension get lowered. The truck will be getting a turbo later on in the season, after we upgrade many other parts of the truck.
Old Jan 31, 2016 | 01:22 PM
YAMAHAGUY's Avatar
Good to know, since I'll be using a standard puller.
I figured I got the project name wrong :-). You make it sound like you are a part of the show. If you are I see a similar truck to "White Noise" in your signature, is this your truck? I don't remember the techs names in this season.
I'm excited to see the Turbo Build. Is this a custome build or a kit?
Old Jan 31, 2016 | 01:26 PM
Yeah, I'm Lawrence one of the co hosts of the show along with Jeremy. I also am excited about the turbo install. It will be a kit, but I can't disclose Whose it is just yet. Yeah, it is my truck.
If you are interested I have an idle video of the cam in here.
http://www.performancetrucks.net/for...inside-541158/
Old Jan 31, 2016 | 01:37 PM
YAMAHAGUY's Avatar
Glad to hear its your truck and it will be a fun ride. Sounds good. I just got my cam and valvetrain parts in. My cam will probably be a little choppier with a 214/218 .559/.562 111 LSA
What's the idle set at? Depending how choppy mine is, might determine how high to set the idle.
The build should be fun.
Old Jan 31, 2016 | 01:44 PM
Thanks. Yeah with the tighter LSA it should definitely lope a little more. I think in the video it was idling around 750rpm.
What year truck is it going in? Be sure to post up a thread when you do the install.
Old Jan 31, 2016 | 02:01 PM
YAMAHAGUY's Avatar
I started a thread yesterday. Looking to do a 5.3 ECSB 01 or 02 so I don't have to mess with return fuel line when I add a turbo kit. I don't have a truck yet, Gotta sell my 2013 Tacoma first. I don't mind converting the returnless system to a return style, I just want to change the GM design and keep it as close to factory as possible since it will be my DD. looking to stay around 500 WHP. Some have said having the 03+ returnless system keeping around that HP range with low side of boost I might be able to get away with adding a little bigger injectors and pump as long as it's not too big.
Old Jan 31, 2016 | 04:01 PM
03sierraslt's Avatar
You can get a returnless system to support 500.
Old Jan 31, 2016 | 05:07 PM
YAMAHAGUY's Avatar
500 at the crank or the wheels? What max size pump do you think a returnless system could handle?
Old Jan 31, 2016 | 05:54 PM
George C....'s Avatar
Formerly ScreamingL
What happened to the other dude who was there for years?
