Post your Timing and PSI
#41
yeah you will be fine. it will have power left for sure, but not dangerous. a few of the guys that like to keep low timing really need to try using an egt sensor. will really teach a lot!
i run mine at .030, but have ran .028 as well. may have been in my head, but light throttle seemed to really suffer from the change.
#42
I'm not spraying any water/meth at the moment with 11.0 AFR (0.778 lambda) and 11 deg of timing.
I just bumped it up to lambda 0.786 and 13 deg of timing and will try it out tomorrow. And I'll get some BR7EF's ordered. What gap would you recommend? 0.028" seems common.
#43
when tuning WOT set your fueling to lambda .78 plus or minus (.02) what ever you feel comfortable with. now on to the timing. you don't want reduce timing so much that your turbo is glowing red. increased timing will reduce egt. once you have reach the limits for your timing and your egts are still excessive more fuel can be added to help cool things.
#47
Not sure if I have adjusted the knock sensors, if I did all I did was use less sensitive settings from another stock tune, maybe from a ZO6? Can't remember.
#49
Just looked and my knock sensor settings are 100% stock. I am hesitant to change them mainly because I don't want to conceal real knock. Any suggestions?
Also the stock tables between my truck and any other stock 01/02 truck/f-body/vette tunes are way different. Mine seems to be an outlier, which is strange because I'm pretty sure there are zero physical differences between an '01 and and '02 5.3L truck engine. Maybe GM just came up with better settings? They are basically the complete opposite at low RPM and high RPM, but are similar in between.
#50
You have aftermarket valvetrain, which is noiser. It makes sense that the knock sensors would need to be desensitized some. As I've said before, there is widely varying settings from the factory on LS equipped vehicles. Although, the 5.3 is setup significantly less sensitive than the 6.0 from the factory.
