possible boost issues
this might be a silly question, i am running 12lbs. with a procharger. it hits 12lbs when at 5000rpms (red line for now) then shifts and drops to 6ish lbs and climbs as the rpms do. so the question is is there a way to maintain 12lbs all the time once at WOT.
i have a 2000 stall in there now. i want to keep it street friendly. i see alot of you running 3000 -3500 plus stalls, isn't that reving the crap out of it just trying to take off from a stop in normal driving.
Im sure this was said beacuse of the difference between a turbo and belt driven supercharger make boost.
Its good your rich so your on the safe side, but a live person tune will def. help dial your combo in more.
A performance torque converter will help you stay in a " better" rpm range that will compliment where your blower is strongest/ in turn lessining boost drop and helping your combo get into and maintain max boost.
If your running a 60E, the yank TT3000 is a nice tight converter that you can DD and almost not notice it.
Also gear change would help some since those prochargers like rpms.
i think rich is an under statement. it is lower than 10:1 from what my one that plugs in to the exaust says, im wanting it to be around 12-13:1 when redune. with 9:1 comp. is this to high?
